Tap53 57 #1 Posted April 13, 2012 Hey, this will be a normal post, One of the USED D200/K532 I purchased has some very very severe wear, the clutch looks like it has been run with a damaged bearing for sometime, bore is egg shaped about 3/16, clutch plate and everything is shot..nothing salvageable. Crank is shot also, but have a new in box rebuild kit, crank, pistons, ect. so that's not a problem, what would your opinion be as far as replacing the clutch, I have a single groove electric clutch somewhere here but would like the 2 groove mechanical.. Thanks, Tim :confusion-scratchheadblue: Share this post Link to post Share on other sites
pfrederi 21,295 #2 Posted April 13, 2012 Check with Kelly here he may have something and put a want ad on. They appear on Ebay sometimes also. The D160s with onans used an electric clutch. I prefer a manual PTO, you can ease it into engagement saving a lot of shock to the implement and the motor Share this post Link to post Share on other sites
slufoot733 70 #3 Posted April 13, 2012 On eBay right now. Two days left: http://www.ebay.com/itm/230774184765?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649 Share this post Link to post Share on other sites
Tap53 57 #4 Posted April 13, 2012 On eBay right now. Two days left: http://www.ebay.com/...984.m1438.l2649 Thanks, I'll take a look Share this post Link to post Share on other sites
