gsinal 1 #1 Posted April 9, 2012 got this when i bought my 520hc and dont know what the are or whee they would go. any help the quart of oil is for refrence for size of parts. thank you Share this post Link to post Share on other sites
ba2988 28 #2 Posted April 9, 2012 The part on the right is a piece needed to lift implements on the rear of the tractor. It installs under the rear fender just above the transmission - and you would need a cable running through a tube which attaches to the rock shaft (I think thats what its called) at the middle of the tractor. Part on the left I'm not sure of but it looks like the lift bar that attaches to a mower deck or snow plow to lift them up. Share this post Link to post Share on other sites
MalMac 1,333 #3 Posted April 9, 2012 The smaller part goes under your seat pan in between the pan support. It is part of your lifting mechanism your clevis hitch and also used on lifting the tiller. The other part looks like part of a t-bar for lifting mower deck and plowblade. Share this post Link to post Share on other sites
darren 49 #4 Posted April 9, 2012 The item on the right looks like a lift hitch. it'd mount the other way up, with the two ends of the rod going through plastic bushings at the top of the U-shaped bit of metal above the trans (the one which the fuel tanks sits around. It should have some circlip grooves to locate it. The notches are for the end of a chain which goes to the rear hitch. I'm guessing the one on the left is a lift arm of some description that goes under the belly of the tractor.. I'm sure someone more knowledgable will be along in a moment :) Share this post Link to post Share on other sites
leeave96 490 #5 Posted April 9, 2012 The item on the right is the lift for the clevis hitch. The item on the left, I am 99% sure is the mower/blade lift arm and goes under the tractor. Both are keepers until you get more familiar with the tractor and attachments to see if you need/want to use them. Good luck, Bill Share this post Link to post Share on other sites
6wheeler 669 #6 Posted April 10, 2012 Right one is a rockshaft for lifting implements(you need 2 bushings and c-clips to go with it) left is the lift bar for decks or plow and such. rear? mystery oil container. Looks like it will hold up to a quart, maybe just a touch more and it is reddish pink in color probably containing some sort of petroleum based or synthetic based lubricant of unknown viscosity. Then there is the potting type bench holding it all with some sort of mystery container being yellow and black in color beneath it all. And, what appears to be a house or other type building directly behind it all . My sig.says I have useless information(its not like you weren't warned) . Nice paint on the parts. 1 Share this post Link to post Share on other sites
CasualObserver 3,411 #7 Posted April 10, 2012 Then there is the potting type bench holding it all with some sort of mystery container being yellow and black in color beneath it all. And, what appears to be a house or other type building directly behind it all. Look like steps to a door threshold to me.... not a potting bench. :ychain: 1 Share this post Link to post Share on other sites
WH854 45 #8 Posted April 10, 2012 got this when i bought my 520hc and dont know what the are or whee they would go. any help the quart of oil is for refrence for size of parts. thank you Chas Share this post Link to post Share on other sites
Rooster 192 #9 Posted April 10, 2012 Then there is the potting type bench holding it all with some sort of mystery container being yellow and black in color beneath it all. And, what appears to be a house or other type building directly behind it all. Look like steps to a door threshold to me.... not a potting bench. I would have to agree, most likely used for entranced into the attached dwelling? Share this post Link to post Share on other sites
6wheeler 669 #10 Posted April 11, 2012 Then there is the potting type bench holding it all with some sort of mystery container being yellow and black in color beneath it all. And, what appears to be a house or other type building directly behind it all. Look like steps to a door threshold to me.... not a potting bench. I would have to agree, most likely used for entranced into the attached dwelling? Gentlemen, I stand corrected. It indeed Does look like steps. However, they may as well be used as a potting bench... Or parts storage . And welcome to this humble and knowledgeable place called (drum roll please) REDSQUARE :greetings-clappingyellow: :greetings-clappingyellow: Share this post Link to post Share on other sites
gsinal 1 #11 Posted April 11, 2012 they are steps to my porch. Thank you guys for the help. When i was in need of new tractor i looked on craigslist every day and now that i have this wheel horse a 520 hc and see how well they are built i am back to looking for another wheel horse. i think i am getting addictied. Share this post Link to post Share on other sites
mrocket49 23 #12 Posted April 11, 2012 Actually, I think he was asking about the yellow thing which is partially obstructed by the wooden steps with those red things on it. Could you post a better picture of the yellow thing? :razz: Share this post Link to post Share on other sites
gsinal 1 #13 Posted April 11, 2012 Its a 5 gallon bucket Share this post Link to post Share on other sites
Rooster 192 #14 Posted April 11, 2012 See if there is a camshaft in it...I been missing a Cam for 5 years and I KNOW I put it in the bucket with all the other parts! Maybe your bucket is the other end of the bucket parts portal that mine apparently has? Share this post Link to post Share on other sites
bowtiebutler956 650 #15 Posted April 11, 2012 :WRS: Let the addiction begin! Matt :flags-texas: Share this post Link to post Share on other sites
