Olratlr 25 #1 Posted April 8, 2012 Guy's I need your help! I am trying to hook up the Tiller off my 520H on a Raider Nine I saw a article a while back where a guy did this with the same belt system does the axle brackets go underneath the axles are to the rear of axle? Thanks Norm Share this post Link to post Share on other sites
MaineDad 87 #2 Posted April 8, 2012 Norm, The older style raider tiller uses a different style axle bracket. Which bracket do you have? Share this post Link to post Share on other sites
Kelly 1,033 #3 Posted April 8, 2012 If the tiller was on a 520 use the axle bracket off the 520 the mid idler pulleys will fit right on, as will the belt, BUT you will have to set up a lift cable to raise it, the old tractors do not use the under seat rockshaft, because of the tool box/tray. Share this post Link to post Share on other sites
Olratlr 25 #4 Posted April 9, 2012 The Brackets and Tiller are on a 520H Share this post Link to post Share on other sites
Austin M. 0 #5 Posted May 3, 2012 Can u post pics of how to hook up the tiller? Share this post Link to post Share on other sites
