Olratlr
Tiller
Olratlr
Guy's I need your help!
I am trying to hook up the Tiller off my 520H on a Raider Nine I saw a article a while back
where a guy did this with the same belt system does the axle brackets go underneath the axles are to the rear of axle?
Thanks Norm
MaineDad
Norm,
The older style raider tiller uses a different style axle bracket. Which bracket do you have?
Kelly
If the tiller was on a 520 use the axle bracket off the 520 the mid idler pulleys will fit right on, as will the belt, BUT you will have to set up a lift cable to raise it, the old tractors do not use the under seat rockshaft, because of the tool box/tray.
Olratlr
The Brackets and Tiller are on a 520H
Austin M.
Can u post pics of how to hook up the tiller?
