BPjunk 184 #1 Posted July 8, 2008 Nicks latest tractor promted me into this post ..... Here's a gem I got from the Northern Neck part of Virginia. Can you guess what the white part is???? <_< Wild Bill in Richmond, Va. Attached Image Share this post Link to post Share on other sites
CasualObserver 3,406 #2 Posted July 8, 2008 Since it looks like it leads to the sparkplug end of a vert and it's long enough to touch the frame, my guess is it's the kill switch for grounding out the plug. B) Share this post Link to post Share on other sites
combatmp29r 27 #3 Posted July 8, 2008 Yep I concur Jason, and it looks like its made from one of thos emetal rails you can rack sockets on. B) Share this post Link to post Share on other sites
Rollerman 290 #4 Posted July 8, 2008 This is obviously a sacrificial anode designed to prevent the tractor from rusting...... B) Share this post Link to post Share on other sites
nylyon-(Admin) 7,136 #5 Posted July 8, 2008 I think it's to pull the plug wire off not ground it. Share this post Link to post Share on other sites
linen beige 14 #6 Posted July 8, 2008 If'n 'at dare thang wuz metal an' wood grownd out the plug, I woodent touch it, it mite bite! Gonna keep us in suspense Bill? Share this post Link to post Share on other sites
HorseFixer 2,012 #7 Posted July 8, 2008 The White Part Is A Pice Of Plywood That Has Been Cut Into A Stick & Has Black Electrical Tape Holding It Onto The Plug Wire. Most Likely Used To Remove The Plugwire From The Plug Hence Killing The Engine, Just Like Karl Said! Duke Share this post Link to post Share on other sites
Jim_M 178 #8 Posted July 8, 2008 The White Part Is A Pice Of Plywood That Has Been Cut Into A Stick & Has Black Electrical Tape Holding It Onto The Plug Wire. Most Likely Used To Remove The Plugwire From The Plug Hence Killing The Engine, Just Like Karl Said! Duke Yup, that's exactly the way I see it. Share this post Link to post Share on other sites
DOC in Kentucky 178 #9 Posted July 8, 2008 Oh. the old "Hillbilly" kill switch. Very common here in Kentucky And when there's a string tied to the stick, Its the "Hillbilly" remote control kill switch Share this post Link to post Share on other sites
rocking 416 1 #10 Posted July 8, 2008 what part or northen neck? Share this post Link to post Share on other sites
mcwh1950 2 #11 Posted July 9, 2008 it look like a old jack from my car Share this post Link to post Share on other sites
HorseFixer 2,012 #12 Posted July 9, 2008 Okay Bill What Is It? Yer Killin me here! Duke Share this post Link to post Share on other sites
rustbucket 4 #13 Posted July 9, 2008 red neck drunk kill switch??? tie a string to the board the other to the drunk red neck runnin it and when he falls of it kills the motor???? Share this post Link to post Share on other sites
DMESS 24 #14 Posted July 9, 2008 Fess up Bill, YOU made that part! B) Share this post Link to post Share on other sites
BPjunk 184 #15 Posted July 9, 2008 Like the post title is "Ifn's ya' ain't got the right part make one!" The old owner of the tractor did not have a ignition switch on the tractor so this is the ON/OFF switch. Ya' simply pull on the white stick to pull the plug wire off so's ya' don't get shocked! <_< Wild Bill in Richmond, Va. Share this post Link to post Share on other sites
BPjunk 184 #16 Posted July 9, 2008 what part or northen neck? Well this tractor was waiting for me at the Callao Ruritan Park, a guy just left it for me there. Wild Bill in Richmond, Va. Share this post Link to post Share on other sites
Curmudgeon 28 #17 Posted July 9, 2008 Dang, It looked like a stock part to me, and Bill was just jerking with us. :whistle: Share this post Link to post Share on other sites
