hym123 14 #1 Posted March 30, 2012 I restored my c120 with a teky twelve horse ,I rebuilt the carb and if you have read my other post i installed a wells chrysler ignition system in it due to the fact you can't find solid state ignitions any more , i rebuilt the carb when the engine is at mid throttle it hunts but not at idle or full throttle i sprayed throttle shaft with carb cleaner it hunts when i spray it could this be my problem? just don't know why it only hunts at mid throttle other than that it fires right up easy and has great power any one have any idea's Should i take carb all apart and re clean really don't want to Share this post Link to post Share on other sites
AMC RULES 37,235 #2 Posted March 30, 2012 Did it run like this before the carb was rebuilt? :scratchead: Share this post Link to post Share on other sites
hym123 14 #3 Posted March 30, 2012 Did it run like this before the carb was rebuilt? No don't think so but it also ran really bad that is what started the restore come to find out it was my ignition thaat was bad i thought it was blown up but what i found out it was a combo of mis adjusted governer carb high jet and ignition after putting ignition in with the help of chuck from save old iron set the timming correctly i have tweeked the jets on the carb,and throttle cable, just hunts a little bit Share this post Link to post Share on other sites
