Lars 526 #1 Posted March 29, 2012 Well took apart a tranny to my brother it's a 8 speed tranny. took it apart because the gearshifter to 1-2-3 gear was very loos at it.. and we get a bit suprised when we found this innside it.. OMG And find the Hi- Low fork like this... Share this post Link to post Share on other sites
MaineDad 87 #2 Posted March 29, 2012 Been there and done that! Are you going to fix it? Share this post Link to post Share on other sites
AMC RULES 37,253 #3 Posted March 29, 2012 What kind of abuse causes that to happen? :scratchead: Share this post Link to post Share on other sites
meadowfield 2,951 #4 Posted March 29, 2012 the same that destroys keyways and axles ! :ychain: Share this post Link to post Share on other sites
pfrederi 19,465 #5 Posted March 29, 2012 What kind of abuse causes that to happen? It is hard to get 8 speeds to shift high to low. you have to be fully stopped and sometimes you have to let the clutch in and out a couple times before she will slip into gears. These are straight cut gears after all. Some people are impatient and push hard on the high low lever. The fork is not very strong (not one of WHs best designs I think) and easily bent. 1 Share this post Link to post Share on other sites
Lars 526 #6 Posted March 29, 2012 yes i agree This tranny was bad when my brother bought it.. the problem whit it was a very loose gearshifter thats why we took it apart.. then i see this shifter to hi and low.. Share this post Link to post Share on other sites
AMC RULES 37,253 #7 Posted March 29, 2012 What kind of abuse causes that to happen? It is hard to get 8 speeds to shift high to low. you have to be fully stopped and sometimes you have to let the clutch in and out a couple times before she will slip into gears. These are straight cut gears after all. Some people are impatient and push hard on the high low lever. The fork is not very strong (not one of WHs best designs I think) and easily bent. So in a case such as this...you're saying, impatience in not a virtue? :thanks: Share this post Link to post Share on other sites
can whlvr 994 #8 Posted March 30, 2012 so am i seeing that someone has welded it before,and i broke my fork putting my tranny back together :banghead: Share this post Link to post Share on other sites
