gwgdog66 23 #1 Posted March 23, 2012 I have a 1990 312-8, mdl # 31-12K801, and the parking brake light is staying on when it is running. The parking brake isn't set. The tractor runs and mows just fine. I'm trying to figure out where the parking brake switch is located, so I can check it to see if it might be stuck or unplugged. I've looked at the parts diagram, and I'm not finding a brake switch. Any help will be appreciated :grin: Share this post Link to post Share on other sites
Moparfanforever 897 #2 Posted March 23, 2012 My back light on my 310-8 comes on with the headlights , didn't know it was a brake light ??? I guess you are talking about the light on the fender pan ?? :eusa-think: Share this post Link to post Share on other sites
BOWTIE 226 #3 Posted March 23, 2012 HELLO, IF YOU MEAN THE DASH IDIOT LIGHTS. THAT SWITCH IS BY THE SHIFTER CONSOLE. IT IS THE LEVER YOU PUSH WHEN SETTING THE PARKING BRAKE. REMOVE THE CONSOLE PLATE THERE WILL BE A MICRO SWITCH WITH A 3 WIRE PLUG. CHECK THE CONNECTIONS AND SWITCH. BOWTIE IN OHIO Share this post Link to post Share on other sites
gwgdog66 23 #4 Posted March 24, 2012 HELLO, IF YOU MEAN THE DASH IDIOT LIGHTS. THAT SWITCH IS BY THE SHIFTER CONSOLE. IT IS THE LEVER YOU PUSH WHEN SETTING THE PARKING BRAKE. REMOVE THE CONSOLE PLATE THERE WILL BE A MICRO SWITCH WITH A 3 WIRE PLUG. CHECK THE CONNECTIONS AND SWITCH. BOWTIE IN OHIO My back light on my 310-8 comes on with the headlights , didn't know it was a brake light ??? I guess you are talking about the light on the fender pan ?? :eusa-think: Yes idiot light is what I should have referred to it as. Thanks fellas. I think it might be this switch if I find out it's bad 116796- SWITCH-PUSH BUTTON ?? Share this post Link to post Share on other sites
