1054josh
hy-2 pump mount on a 702
1054josh
i would like some help on how to mount the pump to the tower. The 702 has a manual lift thats wore out and i have the pump and cylinder but unsure about how to mount and where thanks Joshpost-6518-0-02086900-1332200613.jpgpost-6518-0-67596600-1332200652.jpg
Kelly
You will need the plate that bolts to the pump face, the big plate that bolts to the tower that the plate on the pump bolts to, the small pulley that goes on the end of the crank to run the pump, belt guard, bracket that bolts to the rear axle, the rock shaft that replaces the lift arm, and on a 702 they had a box to relocate the push button and key switch, I have pics of one mounted on a 63 tractor pretty much the same, but the switch box is not needed, and the rock shaft is different for the 63 up tractors, I can try to get pics of the parts you will need in the next few days, these are of my 63 machine to give you a idea.
And :WRS:
1054josh
thanks all that info helps. a pic of the mount on the tower would be helpful so i know what im looking for. i have the right pulley on motor and the plate on the pump. i also have the mount for the rear axle i just dont have the mount on tower and the rock shaft parts.
Kelly
The pulley for the engine is very hard to find, it's a single sheave, and is just a little smaller in diam. than the 3 sheave engine pulley, and it is narrow for a 3/8" belt.
I'll get pics of the all the parts, in a day or so.
1054josh
Ok thanks so much it all helps
stevasaurus
If Kelly does not have the parts, try sending a PM to IndyWH...he is selling o-rings and gaskets for these, he may just have what you need to make it whole. :)
Kelly, that looks real nice on that 63'.
GT14
Nice job, I did the same years ago with an electric over hydraulic convertible top lift.
Kelly
I got a few kinda better pics of the mounts on the tractor.
If you look close you can see the add on pulley is smaller than the drive pulley, and is for a 3/8" belt not a 1/2" like the drive pulley
Axle bracket
Rock shaft on my 63
Kelly
Here is pics of most of the parts to install a HY kit.
Bracket that bolts to the dash tower
bracket that bolts to pump
Belt guard for pump pulley
switch box needed that bolts to the left side of the dash tower to mount the push button and key switch, if you look at my post above of my 63 you can see they put holes to mount the switches in the 63 and newer tractors Picture is sideways left side of pic is bottom.
rear axle bracket to mount the lift cyl.
Rock shaft for the 61 and 62 tractors
Rock shaft for 63 and newer tractors
add on pulley needed to run the pump, takes a 3/8" belt
1054josh
I just pm u thanks a bunch it all helps
Kelly
There externally is two pumps, the first is for the add on HY kits, note how the valve sticks out and the handle screws in to it.
This pump is from a 953 or 1054, note how the valve is flush with the pump face, the handle is made of flat stock and bolts on withe two screws, no handle on this pump.
Both pumps will work, but to be correct you need the round screw in handle, also be sure the return spring is good, you should be able to pull the handle foward or back and it will self center, if not it will have to come apart and a spring put in it, there is two style springs, you have to open it to be sure what one you have.
1054josh
Martin
kelly,
that pulley looks similar to the hyd. pump side of the two row pulley on my 1054. do you think that wh used the same dimensions and added the drive side to make the double?
Kelly
I'm going to say yes Martin, it probably is I know the pump pulley is the same, so to keep the ratio correct the front pulley should be the same diam.
AMC RULES
Is it difficult to rebuild these pumps, any special tools required? :scratchead:
1054josh
I tore mine apart last night with minimal effort and didnt have any special tools other than small long punch to get out the spring pin that was holding the return to center spring in.of coarse it was broken so now lookin for an old style spring
AMC RULES
Did you take any picts to document the process Josh?
1054josh
I did but camera was set to high of resolution and the forum wont allow that big of file to be uploaded but i will change that and definitely change that and take more and then post them sorry bout that
AMC RULES
:thanks: :thanks: :thanks:
Kelly
Here is the two style springs, the first is the later style, a much better set up if you ask me.
This is the early style.
new style ready to put back together, nothing hard to them, unless the early style spring is broken, then getting the pieces out can be a pain.
lift cyl. ready to assemble
1054josh
Laugh out loud so that's what my spring supposed to look like
Martin
i have done one for my 1054, some info is in my 1054 rebuild thread and im going to say it wasnt that difficult from what i remember. theres many others on redsquare that have done them too......
i have the later style spring in mine. if you do a search for hy-2 pump or hein-werner or similar theres a bunch of info on redsquare on this subject. theres also some manuals......
HY-2_A-7140.pdf
HY-3_A-7140.pdf
AMC RULES
Thanks Martin. :)
1054josh
This is the center bolt that i took out to get pump reservoir off
this is were the spring is supposed to mount to the control lever
this is were the spring mounts to pump housing to return the control lever to centerpost-6518-0-98705500-1332896680.jpg
once this rod is unscrewed u can remove the snap ring clip
then the control is pushed out and the only seal on it is a o-ringpost-6518-0-85490900-1332896678.jpgpost-6518-0-92774400-1332896679.jpg
gears under the coverpost-6518-0-58267300-1332896682.jpgand the new pump shaft seal from napa thats behind the drive pulley
AMC RULES
:text-goodpost: :text-coolphotos:
