JFS 0 #1 Posted March 19, 2012 What do you use? I saw a mini tire changer in Northern Tool and Harbor Freight for $40.00 but don't know how well that would work. I have used flat bar and that can be a tough job even with lube. Any ideas??? Thanks Jim Share this post Link to post Share on other sites
jimt1971 237 #2 Posted March 19, 2012 Front or Rear. For the rear find a friend with a tire machine. For the front I just used brute force. Jim Share this post Link to post Share on other sites
JFS 0 #3 Posted March 19, 2012 I'm replacing both sets. Share this post Link to post Share on other sites
AMC RULES 37,251 #4 Posted March 19, 2012 Did both my fronts and rears by hand, you gotta want it though. Definitely a workout. :) Share this post Link to post Share on other sites
speedyleedy 205 #5 Posted March 19, 2012 We use one of them at work to change maintence & shipping carts with 10" & smaller they work great as long as you got them clamped down good i got one at home on a stand ! well worth the money i think :eusa-think: Share this post Link to post Share on other sites
WheelHorseSteve 56 #6 Posted March 19, 2012 If you can get your hands on the "original" Harbor Freight one you can do a lot of tires! Three problems with it -- 1) It will scratch the heck out of your painted rims unless you use some padding under the "clamp" and invest in a Mojo lever (well worth the money!) 2) The bead breaker is weak / poorly built. Reinforce or replace... and leverage a little 2x4 underneath for a little extra height / better angle 3) For front rims, you may be better off building a smaller platform to put on top. My neighbor did this and used a threaded barbell end to hold the rim on... works great! He and I have saved a ton of money with this device... and the rims come out unscathed. Well worth it (again, if you can find it!) Share this post Link to post Share on other sites
Forest Road 595 #7 Posted March 19, 2012 I use a manual floor mounted tire changer. It's a breeze. Another option is to go to a local automotive tire shop and ask them for a price. They could definitely do the rears. Let us know how you make out. Share this post Link to post Share on other sites
tgranthamfd 29 #8 Posted March 19, 2012 We've got a small one that clamps in a vise, we use it along with bars and screw drivers to get the job done. The 12" are not bad to do, but the 6" and 8" are a little tougher. Not a one man job, on the smaller ones. Share this post Link to post Share on other sites
Sparky-(Admin) 24,090 #9 Posted March 20, 2012 I have the Harbor Freight Mini changer and its fine on 2 ply tires. Mounting and dismounting 4 ply's are a workout if you ask me. I just had a pair of 23x10.5x12 tires removed and two new 4-ply 23x10.5x12's mounted at my TORO dealer and it was only $25. I thought that was reasonable. Mike........... Share this post Link to post Share on other sites
gwgdog66 23 #10 Posted March 20, 2012 We've got a small one that clamps in a vise, we use it along with bars and screw drivers to get the job done. The 12" are not bad to do, but the 6" and 8" are a little tougher. Not a one man job, on the smaller ones. What he said. The 6" rims can whoop a fella, in round one and cause sun glasses to fly across the shop never to bee seen again :ychain: Share this post Link to post Share on other sites
can whlvr 994 #11 Posted March 20, 2012 i use irons by hand,even do my skid steer that way and they are tough to do alone,but it can be done Share this post Link to post Share on other sites
JFS 0 #12 Posted March 20, 2012 I picked up a manual tire changer from Tractor Supply like the one in the you tube video. It worked great for the 12" rears but the fronts won't fit on the changer with the pressed in bearing. Thanks for all the help Jim Share this post Link to post Share on other sites
kpinnc 16,303 #13 Posted March 20, 2012 I break the beads with a 30-60 inch 2x6 and my truck. First, remove the valve stem cores so you have free flow of air. Lay the wheel/ tire down in the yard, set the 2x6 like a ramp just short of the edge of the rim, GENTLY drive the truck up and POP. Bead broken, tire comes right off. Obviously I would only do this with a tire I have no use for. For removal of a good tire- take it to a tire shop. :) Share this post Link to post Share on other sites
jimt1971 237 #14 Posted March 20, 2012 Jim, I did not realize your were in Doylestown. I live in Trevose. I could have let you use my tire machine. Next time you need something PM me. Jim Share this post Link to post Share on other sites
WheelHorseSteve 56 #15 Posted March 20, 2012 I picked up a manual tire changer from Tractor Supply like the one in the you tube video. It worked great for the 12" rears but the fronts won't fit on the changer with the pressed in bearing. Thanks for all the help Jim You have to take the bearings out... and even then it won't fit those rims as they are typically 1-3/8" holes. So, if you fabricate a platform and use a barbell end to hold the rim on it allows you to leverage that tire changer for the small wheels/tires. Share this post Link to post Share on other sites
JFS 0 #16 Posted March 20, 2012 I got the tires off the front rims with a lot of elbow grease. But before I put the new tires on there was some rust inside. I used my 2" air grinder and cleaned them up then a little wire brushing now I'm degreasing them. What paint is used on the rims it appears to be silver or grey. Thanks again Jim Share this post Link to post Share on other sites
farmer 1,081 #17 Posted March 20, 2012 Maybe I'm a bit of an ape, !! but I find 12" and 8" really quite easy with lever's. The 6" front's, I had previously on my 312 however.....they stick in the memory. :twocents-twocents: Share this post Link to post Share on other sites
