otrelwood 32 #1 Posted March 18, 2012 i have a d 180 that obviously had the soft bolts in the carrier as the case is welded together . it also has a bad axle bearing because the axle is real slopy and leaks oil real bad .anyway i have purchased another axle from my favorite WH vender and swapped the axle,everything is the same except the original tractor has 2 hoses coming out of the bottom of the motor that go up to a box that is bolted to the inner fender does anyone know what that box thing is ? all it seys on it is hydralic devices sarasota florida thanks in advance for any information Share this post Link to post Share on other sites
73-18 automatic 8 #2 Posted March 18, 2012 It is a hydraulic damper not all D's had them Share this post Link to post Share on other sites
otrelwood 32 #3 Posted March 18, 2012 is that a good thing? Share this post Link to post Share on other sites
pfrederi 19,244 #4 Posted March 18, 2012 It dampens the shock of going from forward to backward. if you take your time and don't jerk the control lever between forward and reverse it is probably unnecessary. If your teenager is driving you probably want one. Share this post Link to post Share on other sites
wheeledhorseman 579 #5 Posted March 19, 2012 My D-200 has these although the manufacturer of the damper valve unit is different. I'm sure someone will jump in and correct me if I'm wrong but when I did a bit of research to find out what they were I remember reading that they were dropped from later production models. So if this was a cost cutting decision then I guess that they're not totally necessary. As Paul said, if you use the tractor sensibly then you're ok to leave them out. Andy Share this post Link to post Share on other sites
pfrederi 19,244 #6 Posted March 19, 2012 They were not on early models or late models. Share this post Link to post Share on other sites
Hodge71 691 #7 Posted March 19, 2012 My 18 auto doesnt have one. I was going to add it while I have this thing torn limb from limb but after doing reasearch about them and seeing that they dropped them from the later years I decided not to. I think you'd really have to abuse the tractor for it to be mandatory. Share this post Link to post Share on other sites
