Retired Wrencher 6,170 #1 Posted March 13, 2012 :USA: I would like to know if any one has info where I can find this rubber grommet that goes over the pipe that feeds the carb. There was a post last summer some one converted to1/4 tubing, I sure it works fine but those brass nipples are big $$$$$$$$$$$$$$$$$$$$$$$$$$ so here are a few picks notice the rubber is stating to flake off. Gary B...................... the 1st pick Share this post Link to post Share on other sites
rmaynard 16,699 #2 Posted March 13, 2012 What model is this for? Share this post Link to post Share on other sites
Retired Wrencher 6,170 #3 Posted March 13, 2012 Bob this for the 857/1057/and the 1257 I belive they are all the size. Gary B.............. Share this post Link to post Share on other sites
Fun Engineer 860 #4 Posted March 14, 2012 I have a friend that is a diesel mechanic and he was able to get some for me. I don't know what he used them for but they fit perfect. Share this post Link to post Share on other sites
Martin 2,133 #5 Posted March 17, 2012 gary, it was me that did that conversion with the compression fittings last summer. i think you would be surprised how inexpensive this is to do. the fittings are $2.39 for the elbow and $2.09 for the straight one. make up a small length of 1/4 brake line to fit and im sure i did the whole thing for under $6. i just did another one today on the 1277. the female part of the compression fittings that are on the old system are almost identical to the newer 1/4 inch ones. in fact the 1/4 inch pipe will fit in the old female fittings so you could even leave these on the pump and carb, ( the pump one is very hard to get off if you dont remove or shift the pump away from the cam gear cover. sure beats the uncertainty of rubber deteriorating from modern fuels and additives. heres some pics........ old setup.... here is the old and new. the fittings on the new one (threaded part) are old ones with new pipe, ferrules and compression nuts. heres the new elbow in its packaging...... Share this post Link to post Share on other sites
