Docwheelhorse 2,875 #1 Posted March 13, 2012 Hello all, I picked up a clean C111 with the Briggs in it (I hear all the sighs.... leave me alone---there my favorite!!! ) anyways... the bearing plate/needle bearing drive pulley is tight and in great shape. My mod question is all follows----this tractor has the wonderful (siggghhhhh) rubber biscuit cradle and this motor sits there jumping around like an angry Harley.... air filter vibrating and all. So....... I have a solid mount off of a GT2500 which is the 25th anniversary Wheel Horse with the Briggs 11/solid mount and gas tank on engine. I'd like to lift the engine off the biscuit mount and slide the solid in there----do you guys think this is a good idea or did the biscuit mount actually help the bearing plate etc.... stay pretty much wear free? Whats your thoughts? Tony Share this post Link to post Share on other sites
Rooster 192 #2 Posted March 13, 2012 Easy fix..let me build you a better briggs... I have pulled iso mounts out of many different tractors with briggs engines. never had it cause any problems. Share this post Link to post Share on other sites
tarcoleo 120 #3 Posted March 13, 2012 I have two C's with iso mounts. No problems with vibration with replaced Honda power. If the stock iso mounts are too springy for you suggest you replace them with DIY mounts made up of fender washers/rubber washers combination. Suitable rubber washers can be fashioned from cheap rubber mallets available in Dollar Stores and the like. Tom Share this post Link to post Share on other sites
MikesRJ 558 #4 Posted March 13, 2012 Advice? Put a Kohler on it? ... JK Share this post Link to post Share on other sites
leeave96 496 #5 Posted March 13, 2012 I had two C111 tractors, like you said good machines. I seem to recall the hood was slightly notched to clear the air cleaner. Those briggs engines use to vibrate the air cleaner off of them! On the plus side, ANY time gas was presented to the engine, they would start, the C111 was light on the front end and very easy to steer, they had 1-1/8 inch rear axles and the 8 pinion transmission - from what I recall. I wouldn't think going to solid mounts would be a problem and you can always go back if you don't like it. Oh, the engine had plenty of power and was easy on gas too. I used these tractors with a 36 inch rear discharge deck and got the best cut of any of my Wheelhorse fleet. The narrow width of the deck also allowed me to load the tractor in my little Nissan truck between the wheel wells and shut the tail gate too! Good luck, Bill Share this post Link to post Share on other sites
Prater 77 #6 Posted March 15, 2012 We put a 14HP Kohler on our C-111. We just bolted it on the ISO mount and the tractor runs perfect. Its probably our most reliable WH in the fleet. Share this post Link to post Share on other sites
