WHEEL HORSE BILL 7 #1 Posted March 7, 2012 Hi guys I am lookin at a 516H it has no motor and mowerdeck but it has wheel horse wheel weights and chains.I think all it needs is a motor and mowerdeck.this guy wants $150 for it. What is your opinion should i get it for that kind of money. Share this post Link to post Share on other sites
Indy w h 5 #2 Posted March 7, 2012 I'd say buy it !!! The WH wheel weights are worth that !! Share this post Link to post Share on other sites
WHEEL HORSE BILL 7 #3 Posted March 7, 2012 are the weights concrete. Share this post Link to post Share on other sites
Indy w h 5 #4 Posted March 7, 2012 Oh there not cast WH wheel weights ??!! If there in a black plastic shell they could be either sand or concrete Share this post Link to post Share on other sites
Forest Road 595 #5 Posted March 7, 2012 If they're black plastic weights there's nothing special about them. You could buy a new set of plastic weights and have Vinyl guy mak some decals. But whats your purpose for buying this? Parts, full rest, worker? Share this post Link to post Share on other sites
kpinnc 18,483 #6 Posted March 7, 2012 Ask the seller why the engine was removed. If it was bad, then the tractor may be worth the money. If not, then the Eaton pump may be the problem, and the engine was used elsewhere. The domestic 516-H and 518-H tractors used the lighter-duty 700 series pumps. They had about 1/3 of the output torque of the 1100 series pumps on the traditional "-H" model tractors had. Because of this, they were restricted against "ground engaging attachments". The problem with that was that most people used them with those attachments anyway, which greatly reduced the life span of the smaller hydrostatic pumps. The good news is that an 1100 series pump will bolt right in place of the 700, but you'll have to add hydraulic lift as well. The gearbox is the same regardless. Just something to keep in mind. The tractor may be worth the money in parts alone, but it all depends on what you plan to use it for. Good luck! Share this post Link to post Share on other sites
WHEEL HORSE BILL 7 #7 Posted March 7, 2012 This guy seems shady . He told me that his buddy took the engine for his case tractor.I think the rearend is shot if you ask me and thats why he is sellin for 150 dollars.I think i'm goin to stay away from this one.Its been on cl for awhile and why hasn't it sold yet shadyyyyyy.Thanks guys WHEEL HORSE BILL :USA: Share this post Link to post Share on other sites
can whlvr 994 #8 Posted March 8, 2012 ya if you dont need any of the parts from it for your own machines i would walk from that deal Share this post Link to post Share on other sites
