Trouty56
K301 Crankshaft Question
Trouty56
I was looking at parts and came across this crankshaft that is advertised as a Wheel Horse K301 crankshaft. Now I haven't had a whole lot of these engines apart but when I have there is a nut on the flywheel side not a bolt.....what do you think???
smoreau
It looks just like mine, I say it is correct.
Trouty56
Thanks Scott....
Kelly
I can't say it's a 301 crank from the pic but I can say the later Kohlers I have and all the magnums I have, use a bolt to hold the flywheel on, not sure when they started it?
TT
That's also the "fix" for older cranks with bad/broken threaded ends.
Face them off close to the end of the taper and drill & tap 3/8-24 for the new-style bolt.
Much cheaper than buying another crank. :handgestures-thumbup:
Trouty56
Thanks Terry...that's good to know cause I have a ruined crankshaft from me trying to get a flywheel off. You know the one....
rmaynard
Bob,
You can tell if it's a K301 by looking at the counter-weights. K301s are flat. The picture looks as thought it is sitting on the flats.
bowtiebutler956
Just rebiult my K301 and it has a large nut on the crank, not a bolt. :twocents-02cents:
Matt :flags-texas:
