4SPEED 2 #1 Posted February 29, 2012 it has new points, good plug, cleaned the carb, new gas , new gas line & filter. It has good spark.. it'll hit One time, then it just cranks. I think its getting to much gas. the plug is wet... also,, does anyone have a pic of how the governor linkage is hooked up? Share this post Link to post Share on other sites
tunahead72 2,591 #2 Posted February 29, 2012 Just off the top of my head ... Did it run BEFORE all this work? Have you done a compression check? Share this post Link to post Share on other sites
AMC RULES 37,250 #3 Posted February 29, 2012 Not sure, is that the H60 Tecumseh motor? I recently uploaded the H60 parts manual in the files section...might help you out. Share this post Link to post Share on other sites
pfrederi 19,278 #4 Posted February 29, 2012 Did you put in a new flywheel key? They are a soft aluminum alloy designed to shear. Did it backfire when you first tried to start it? Backfiring can deform the key and then you will have a very nice spark but occurring at the wrong time. Share this post Link to post Share on other sites
Terry M-(Moderator) 2,271 #5 Posted February 29, 2012 Could the carb. Float be stuck? Sounds like a lot of fuel . Share this post Link to post Share on other sites
horse700special 2 #6 Posted March 1, 2012 here is some pics of my 6 hp tecumseh on my 65 lawn ranger hope this helps! http://i1137.photobucket.com/albums/n518/dave_ross1/IMG_2064.jpg http://i1137.photobucket.com/albums/n518/dave_ross1/IMG_2060.jpg Share this post Link to post Share on other sites
4SPEED 2 #7 Posted March 1, 2012 Just off the top of my head ... Did it run BEFORE all this work? Have you done a compression check? no it didnt run, no spark. and no compression check. Not sure, is that the H60 Tecumseh motor? I recently uploaded the H60 parts manual in the files section...might help you out. thanks, that will help a lot. and yes it the H60 sorry I left that info out. Did you put in a new flywheel key? They are a soft aluminum alloy designed to shear. Did it backfire when you first tried to start it? Backfiring can deform the key and then you will have a very nice spark but occurring at the wrong time. no I did not. kind of what Im thinkin . its firing to soon or late. I put a new plug in it , and now it'll run about 3 or 4 sec. and yes it has poped outthe carb a few times. not all the time. Could the carb. Float be stuck? Sounds like a lot of fuel . I dont think so, but yes, Sounds like a lot of fuel here is some pics of my 6 hp tecumseh on my 65 lawn ranger hope this helps! http://i1137.photobu...s1/IMG_2064.jpg http://i1137.photobu...s1/IMG_2060.jpg thanks , you the man............. Share this post Link to post Share on other sites
rockinhorse 45 #8 Posted March 1, 2012 4speed Just went thru the same thing. I got a carberator rebulid kit and rebuilt the carb. Make sure you clean all the vents real good . The float is tricky to set . Once i got it set right it starts good. I also put a new plug in . I used a NKG 3510 Share this post Link to post Share on other sites
4SPEED 2 #9 Posted March 1, 2012 what is the carb kit and flywheel key going to cost?? and who sells it? soaking money into it , I dont what to do when its only use will be to drive it in the yard. Share this post Link to post Share on other sites
rockinhorse 45 #10 Posted March 1, 2012 4SPEED carb rebuild kit cost me almost $15, couple cans of carb cleaner $6 to $7. I got my carb kit from carquest. You can get flywheel key at auto store maybe $1. besure and take the old one to get one the same. karl Share this post Link to post Share on other sites
4SPEED 2 #11 Posted March 1, 2012 are the auto parts store carb kits ethanol safe. I know the kits they sell for my 70's cars Q-jets are not. the gaskets and o-rings brake down in the ethanol. todays gas is hard on the old engines I check with the auto store tomorrow. Share this post Link to post Share on other sites
