cdn97
Work Horse 700 - Kohler Engine Recoil issue
cdn97
I have a Kohler engine that is a pull start with recoil. I have the spring in, it recoils fine. The issue now is the "fins" that turn the flywheel don't come out until it recoils. What's wrong? Something is backwards, but I am not sure what. Any ideas?
bowtiebutler956
Sorry I cant help with this, as I have never heard of that happening before, but I'm sure someone here has and will chime in before long. Matt
can whlvr
look in the download area and see if the kohler rebuild manual is there,when i rebuilt my last engine i noticed the manual has a section on starters,a big area on recoils,im not sure of the manual for an engine that old but in the magnum manual there was a good section on these,you may have to download it from kohler,ive done this and its free,go to the links area and you can get to kohler from there
KC9KAS
Are you sure it is a KOHLER?
Sounds like the spring and rope may be wound backwards...Really haven't had this problem before, so I am guessing.
cdn97
yes its a kohler - engine has been replaced on this tractor. I will look into these ideas and let you know.
