duelldanz 1 #1 Posted February 24, 2012 just bought out a dealer that folded and got a brand new 80732 dual rear wheel kit, instructions don't say what tractors it will fit only they must have 1 1/8 axles & 8 pinion differentials one side of instructions is for hydro the other side i'm guessing is for standard trans. does anyone know what they fit & about what they are worth? Share this post Link to post Share on other sites
Sparky-(Admin) 23,164 #2 Posted February 24, 2012 I doubt the tranny affect what they will fit. All of our 12" rear rims should have the same 4 mounting holes. The width of the adapter is whats important. What this means is that if the kit was designer for a 520 with 10.5 rear rubber it will give you the proper spacing between the two tires. If the same kit was used with a pair of 6x12's on a 60's vintage tractor you would end up with a huge gap between the two tires. Got any pics of the adapters or maybe the manual/instructions? Does it have pics of a particular tractor in the paperwork? Mike........... Share this post Link to post Share on other sites
duelldanz 1 #3 Posted February 26, 2012 THE SPACERS ARE 11 INCHES LONG BUT PART OF THE KIT INCLUDES NEW AXLES. THERE IS NOTHING IN THE INSTRUCTIONS ABOUT WHAT IT FITS BUT LOOKS LIKE A TRACTOR WITH A HYDRO NEEDS AXLES REPLACED AND SAYS TO REFER TO TRANS REPAIR MANUAL 810 243R2. Share this post Link to post Share on other sites
Old Horse Junkie 0 #4 Posted April 22, 2020 Mine are 11" too. I had made a shorter spacer but found mud was a problem piling up between the tires, causing the tires to spin. I recently put ballast in my tires giving it conciderably more traction. Share this post Link to post Share on other sites
