AMRIV1983 2 #1 Posted February 20, 2012 Guys I was wondering where you go to get a Headlamp cheap. I see toro wants $36.83 for a headlamp and other places online want around $30.00. Is this only 1 headlamp or do they come in a pair? It seems pricey to me. Thanks Addison 1 Share this post Link to post Share on other sites
chris hall 5 #2 Posted February 20, 2012 i just bought one a ebay for $32.00. killians wanted more than that and i didnt pay freight or taxes either. it was new condition. Share this post Link to post Share on other sites
BOWTIE 226 #3 Posted February 20, 2012 HELLO,WHAT TRACTOR MODEL DO YOU NEED HEADLAMPS FOR? BOWTIE IN OHIO Share this post Link to post Share on other sites
AMRIV1983 2 #4 Posted February 20, 2012 Tractor Model is a 520H Thanks Share this post Link to post Share on other sites
Kelly 1,033 #5 Posted February 20, 2012 Try a auto parts store, take your old bulb with you, it is a basic light used in many applications. 1 Share this post Link to post Share on other sites
BOWTIE 226 #6 Posted February 20, 2012 HELLO, YOU CAN THEM FROM NAPA,CARQUEST,OREILLYS. ANY GOOD AUTO PARTS STORE #4411 (35WATT) WITH SCREW TERMINAL. YOU CAN CHANGE THE TERMINAL TO SPADE IF NEEDED. JUST UNSOLDER THE SPADES FROM THE BURNT OUT LAMP. I DO IT ALL THE TIME THEY ALSO MAKE 50WATT)HALOGENS LAMPS THAT SIZE. YOU CAN ALSO BUY THEM ON LINE IF NEEDED 5-10 BUCKS.HOPE THIS HELPS. BOWTIE IN OHIO Share this post Link to post Share on other sites
BOWTIE 226 #7 Posted February 20, 2012 THE CORRECT NUMBER FOR WHEEL HORSE IS 4411-1 WITH THE SPADE TERMINAL. GOOD LUCK BOWTIE IN OHIO Share this post Link to post Share on other sites
Kelly 1,033 #8 Posted February 20, 2012 Most of the 520s use the halogen bulbs, they are pretty bright. Share this post Link to post Share on other sites
can whlvr 994 #9 Posted February 20, 2012 dont know about the 520,but my others use the 4411-1,10 bucks at carquest Share this post Link to post Share on other sites
SAM58 30 #10 Posted February 20, 2012 THE CORRECT NUMBER FOR WHEEL HORSE IS 4411-1 WITH THE SPADE TERMINAL. GOOD LUCK BOWTIE IN OHIO I found mine at a local auto parts store for around $8.00 each. Standard bulb, Share this post Link to post Share on other sites
Butch 194 #11 Posted February 20, 2012 There's a bunch of them on Ebay. Just do a search for 4411. Share this post Link to post Share on other sites
COMMANDO1 23 #12 Posted February 21, 2012 send me a pic,might have a set for sale...someone here can chime in , will the lights work from the gt1100 i am parting out? Share this post Link to post Share on other sites
BOWTIE 226 #13 Posted February 21, 2012 I DON'T THINK ANY OF THE 300-400-500 SERIES TRACTORS HAD HALOGEN HEADLAMPS. TORO SHOWS THE SAME PART NUMBER FOR ALL MODELS WITH SEAL BEAMS #102881. I HAVE A 1988 520H WITH HALOGENS IN IT AND ARE 50 WATT INSTEAD OF 35 WATT. THEY ARE BRIGHTER USING ABOUT 1 AMP MORE POWER FOR BOTH. MOST WHEEL HORSES WITH A 15-20 AMP CHARGING SYSTEM CAN HANDLE THAT. I HAVE SOME OF THE OLD B-C MODELS WITH 1156 BULBS SO ANYTHING IS GREAT TO ME, BOWTIE IN OHIO Share this post Link to post Share on other sites
squonk 43,193 #14 Posted February 21, 2012 We used to sell the 4411 bulb at Napa under the HDP line. The regular 4411 lamp would sell for like $6 and the HDP which included the rubber body and mounting bracket would be $4 Take the bulb out and throw away the rubber body. TSC sells them too under tractor work light. If you want to play with lighting, there are several versions of the 4411 size lamp. I have 4406's on my Power King and it shoots a shorter but wider beam. Who needs to see way out on a tractor? Share this post Link to post Share on other sites
Lagersolut 733 #15 Posted February 19, 2017 Amazon has them for under 10 bucks - Free 2 day shipping for prime members Intella GE sealed beam 35 watts - 6 bucks free shipping - Just search 4411 light bulb . Share this post Link to post Share on other sites
BaySide1 138 #16 Posted February 19, 2017 On 2/19/2012 at 9:27 PM, AMRIV1983 said: Tractor Model is a 520H Thanks just bought two lights at NAPA they were like $8.00 each the part # on the GE Bulbs that were bad was 4411-1 Just got a new set at my local NAPA store #4411-1 they are rated at 12.8 V 35W some one else stated a part number of PAR36 Amazon also has some LED Versions for $19.50 each Share this post Link to post Share on other sites
Tankman 3,523 #17 Posted February 21, 2017 NAPA $5 something. I purchased several on sale at NAPA $4.65 each. Share this post Link to post Share on other sites
