HorseWhisperer
K181 governor
HorseWhisperer
Can anyone post an accurate picture of an unmolested,working governor from a 68 Commando 8.I had non original parts making up mine and would like to make it stock.
TT
Close enough?:
Make sure you check the Kohler service manual too. :eusa-whistle:
HorseWhisperer
I referred to the Kohler service man first but my speed control wheel has a different "nub".It also has a seperate flat linkage that floats under the speed control wheel.The previous owner hacked up a throttle cable holder and I had to fix what wasn't broken.The whole governor is an orangeish Colorado so I was afraid it wasn't stock.This thing has been a great to me for so many years.I just wanna get it back and going.Keeping these machines going is an addiction but thanks to you fellas it makes it a little less frustrating.
TT
The extra tab on the control disc is used with the push/pull control cable to increase the travel. Without that tab, you could only move the cable about an inch between idle & full throttle.
Does the topic I linked to help, or do you need more info? :confusion-shrug:
HorseWhisperer
The tins on the engine are wheel horse red and the block is orange.I have the engine tag id numbers but it doesn't do me any good.
HorseWhisperer
That explains some Terry.I removed and reconfigured and lost top rpms.I am at a lose as to where to pin my throttle cable and where to hook the actual throttle wire.
As there used to be all kinds of non stock weird brackets and fasteners.
My speed wheel doesn't resemble the Kohler service manuals.Who had Orange engines,Jacobson?either way its still a k181s motor
Btw,Colorado=color
HorseWhisperer
Thanks so much Terry!After I put away my staunch stubborn way I fiddled with the info you gave me and it works like new!Is the brass nut supposed to keep tension on the speed wheel and cable mount bracket?It seems as though two of my Reds developed a self closing throttle now!
TT
The brass "nut" secures the cable bracket against the engine block, but the control disc should rotate freely on the shoulder just behind the hex.
The only thing that keeps the control disc locked in position would be the throttle control cable. That's why the old push/pull throttle control had the twist-to-lock feature.
HorseWhisperer
Seems as though I'm gonna needs me some new cables.My cable has been frozen from twist locking for at least ten years.Thanks again Terry!
