Will G 3 #1 Posted February 18, 2012 Took the C-81 for a spin around the yard today and was shifting from 2nd to 3rd and once I released the clutch pedal, the tractor didn't move. Tried moving the hi/lo selector and it seems to be jammed. I'm thinking it popped out of hi range and is stuck in neutral. Share this post Link to post Share on other sites
racinfool40 203 #2 Posted February 18, 2012 Hmmm, I'd start by checking the drive pulley and the woodruff key to make sure you didn't shear it...try rocking the tractor by hand while you try to shift the hi-low lever, But don't force it. The fork that move's the high-low gear is not a very beefy fork and you can bend or even break it.. MIKE Share this post Link to post Share on other sites
Will G 3 #3 Posted February 18, 2012 the drive key is indeed not sheared on the tranny. Share this post Link to post Share on other sites
tunahead72 2,587 #4 Posted February 18, 2012 And did you try rocking it like Mike suggested? Mine will sometimes get hung up like that, and just rolling it a few inches will release whatever pressure is causing the lever to not engage, and then it'll slip right into place. Share this post Link to post Share on other sites
Will G 3 #5 Posted February 18, 2012 Yes I rocked it while trying to move the lever and it still seems to be jammed. Share this post Link to post Share on other sites
MaineDad 87 #6 Posted February 18, 2012 How about the set screw on the shifter? If that's fine and the woodruff key on the pulley is not sheared, than I think you have a broken shifter fork Share this post Link to post Share on other sites
Will G 3 #7 Posted February 19, 2012 I am also thinking that I have a broken shifter fork. Share this post Link to post Share on other sites
can whlvr 994 #8 Posted February 19, 2012 that would suck,but ive done this repair and its not too bad to do,or if you have a spare rear end then a simple swap Share this post Link to post Share on other sites
Wyattrrp 59 #9 Posted February 19, 2012 WillG It seems too obvious to ask but did you check that the rear tire hub did not slide inward on the axle, far enough to let the half circle woodruff key in the axle slot rotate upward 45 deg and disengage the axle from the hub and allow the axle to rotate freely. Read my response at the end of the "Hub Puller" topic in this forum section. When my C125 had this happen, it felt like the unidrive failed like you mentioned, since while in gear, the drive pulley spins fine but the tractor did not move. I could not see the end of the axle sticking out from the hub an inch because wheel weights were on. Looking under the rear at the tranny, the space between unidrive case and the wheel hub should be over an inch of space. Good luck. Worth mentioning even though it seems obvious to at least rule out the obvious.. Wyatt Share this post Link to post Share on other sites
Will G 3 #10 Posted February 20, 2012 Don, I don't have a spare tranny to swap in. Wyatt, I have checked the hubs and they are indeed still in the proper position on the axles so it looks as if I need to open up the tranny and see what is broken. Share this post Link to post Share on other sites
Raider10 3 #11 Posted February 20, 2012 WillGCT, My c105 Had similar problem but was stuck in high range. Turned out to be a broken selector fork. Simple fix but got to split the trans in half. I just migged mine back together as it had snapped clean off and hadnt bent. Ian. Share this post Link to post Share on other sites
chevrat68 19 #12 Posted February 26, 2012 I have that problem with my trans. Mine got water in it and froze. When I split the trans my selector gear had split into 3 pieces. Share this post Link to post Share on other sites
smoreau 658 #13 Posted February 26, 2012 I had one that broke the reduction gear in several pieces, around $90 to replace, Bought a replacement trans for $50 and flushed out the trans and replaced the gear oil and was good to go for less then $100 with new axle seals :) Share this post Link to post Share on other sites
Will G 3 #14 Posted February 26, 2012 Looks like the selector fork for hi/low range is also messed up on my C-111 as well, I can't get it into low range and the hi low lever moves freely. Share this post Link to post Share on other sites
Sparky-(Admin) 23,980 #15 Posted February 26, 2012 Hmmm....two in a row? Are you coming to a complete stop before swapping from hi to low? These are not "Shift on the Fly" tranny's. Mike......... Share this post Link to post Share on other sites
Will G 3 #16 Posted February 26, 2012 Yes, I am coming to a full stop before shifting or changing from high to low Share this post Link to post Share on other sites
can whlvr 994 #17 Posted February 27, 2012 ya its pretty common on tractors that have used a fair bit,i had to do one on my 308 before red square existed,or ebay i think too,so i used the dealer and it was a little pricey as i did all the bearings then too,the next problem i had i bought a spare rear end off of a guy from here,had it shipped to me in canada from kentucky,and it was cheaper then the parts i needed,i swapped the new to me in in no time,and watched ebay for the parts for my orig,it took 1 year but i got those parts for 20 bucks plus shipping,20 bucks,and i got 2 axles,and the ring and pinion gear with pinions,40 bucks,the axle was 350 bucks,gear 80 bucks and pinions were up there,just a thought for you to ponder then you rebuild when you have time and cash Share this post Link to post Share on other sites
Will G 3 #18 Posted February 27, 2012 Both of my Horses have appeared to been worked pretty hard so I think they finally went. Share this post Link to post Share on other sites
