Craig Arndt 6 #1 Posted February 12, 2012 During my restoration, I replaced the 9 pin connector with temporary connectors, until the new one arrives. I numbered each wire, but now, I can't read them. I was wondering if anyone could take a look at their pins and let me know the colors that connect together? I used the demystification guide but it only tells you colors of one side. The other has to be traced though sheaths which is proving frustrating. Man there are a lot of wires! Share this post Link to post Share on other sites
smoreau 658 #2 Posted February 12, 2012 Its only 9 wires Try and fix a burned out fuse block in a newer car, been there and done that with over 150 wires. Just take your time and do one at a time. before you know it you will have it fixed :) Share this post Link to post Share on other sites
Craig Arndt 6 #3 Posted February 12, 2012 LOL! I know its only 9 wires, but I'd prefer not to hook something up and do damage to the test panel or something. Share this post Link to post Share on other sites
Kelly 1,038 #4 Posted February 12, 2012 I just this last weekend replaced the 9 pin connector, I cut the wires about a 1/4" out of the connector on both sides to have a clue where they go, I might have the old connector I'll look in a bit, but mine was a 1995 Share this post Link to post Share on other sites
Kelly 1,038 #5 Posted February 12, 2012 Well my newer 520 is not the same, but I have a parts 520 I think is a 89, it looked at the wiring, not sure how to write this up, but I will try. To start this will be looking at the engine plug as it would face you, not the wire side and the holes with the flats on them are on the bottom, top row left to right Red, white, yellow middle row 2 orange together, Dark blue, Gray Bottom row with the flat sides light blue, Black, Green Now the tractor plug/body side, with the plug facinging you, not the side the wires go in. top row Red, White, Red second row Gray, Dark blue, Yellow Bottom row with the flats White, Black, Light blue see if this helps clear up the way I labled them. top row is self explanitory second row 2 org. hook to the Yellow, blue to blue, gray to gray bottom row blue to blue, black to black, green to white. I can not tell you where the wires come from or go to, the harness is out of the tractor, and has been cut up. I hope this does not confuse you to bad. Share this post Link to post Share on other sites
Craig Arndt 6 #6 Posted February 13, 2012 Thank you very much Kelly that is just what I needed! :bow-blue: Share this post Link to post Share on other sites
Kelly 1,038 #7 Posted February 13, 2012 I hope you can understand my rambling, if not let me know. Share this post Link to post Share on other sites
Kelly 1,038 #9 Posted February 15, 2012 Glad it worked out for you, on the tach issue do you have the I think gray wire piggy backed on one of the leads to the volt reg.? I can double check the color if needed. Share this post Link to post Share on other sites
