Paul D.
Blown Bearing In My Snow thrower
Paul D.
We got over 12" of snow and it's coming down at 2" an hour. I got the drives done but blew out a bearing in the process. Toro dealer doesn't have it. Do tou think my local farm store will? I can't find the pt. # on the thrower. But I pulled the old bearing to compare. This sucks. Best snow of the year and I'm side lined
smoreau
TSC should have what you need, witch bearing blew? If its the idler sprocket or the drive bearing? if its the drive bearing you will need to take the side plates with you to make sure the new bearing will fit rite.
Paul D.
On the parts viewer it looks like its pt.# 101782 but mine doesn't look exactly like that. It't the shaft on the side opposite the pulleys
Paul D.
detail # 21
smoreau
take 21 and both 41 pieces with you to make sure the new insert will fit. If it doesn't then buy there plates so it will work. You may need to drive out a roll pin that holds the bearing on.
Paul D.
Just left TSC with the parts I needed. Of coarse since I'm in Niles I had to stop at rural king too
Kinda funny. There 15 miles away and they might have 3". We have well over a foot. Thanks for the help guys
Paul D.
