Countdown To Christmas!
Don1977
Modified heavy duty hitch
Don1977
Being retired and not much to do out side, I look at my hitch and desided to make a a few changes.
Here I cut off the braces and cleaned up the area.
Then I welded it back together, and added some paint.
While I was taking things a part I got a few more.
I added another piece of steel welded them up and shot a little paint on them.
This is what I ended up with.
I could have put the other hitch on if I had a couple more hands and a lot of patience, but having neither I left it off.
smoreau
Looks Good! Now that's using your noodle, best of both worlds! I like it.
Rollerman
With the reciever hitch installed do you have enough room to run the clevis hitch up all the way?
AMC RULES
Looks like it turned out great, gonna shoot it :wh: red now? :scratchead:
Don1977
It's all the way up in the picture. I move bar on the hitch back 1/4" and added a 1/2" piece of steel behind it to move it away from the receiver. There is about 3/16" between the clevis and the other hitch. I didn't get a picture of the lever assembly but I moved the bar to the other side.
Here is a picture of the lever assembly.
This is on a C-120 8 speed and I moved the flat bar to the left of the one that is attached to the lift cable. Look like I need to hook up the tail light.
Don1977
It matches my front bumper so I'll leave it white.
