Retired Wrencher
Engine stand
Retired Wrencher
:USA: :wh::thumbs2: Hi I had some scrap lumber and I thought I have a couple of Motors not in use, so I built an engine stand that is portable and to my height while in a mechanic stool it is about 3` ground to top. This will also be used as a tire changer that I bought from Harbor Fright. She is real sturdy no wobble at all. If it is in my way just move it. Enjoy the Pick`s Gary B............................ enginestand006.jpgenginestand005.jpgenginestand004.jpg
Paul D.
nice setup should come in handy. Are you going to throw some casters on it?
Sparky
Looks like a handy engine stand. I have the mini tire changer from Harbor Freight and it only works for me if I use it in a bench vise which is on a real heavy bench. While I'm wrestling tires on and off rims the bench sometimes starts to "walk". Your table might not be heavy enough for the tire changer.
Mike........
Retired Wrencher
Thanks Mike If it does not work on this I will put in a cement block in the ground with threaded rods this should do the trick. I was thinking only do the fronts anyway the rears look good for now. And Paul no I what it to be flat on the ground as I said it is light but sturdy. and not high from the ground. it is a custom made for me,and my height. I think low to ground is the way to go for leverage. Gary B.......
AMC RULES
Yeah, that's cool. :eusa-think:
zach l
yeah they are very handy i built one a few weeks ago this i what mine looks like enginestand-1.jpg
