Paul D. 26 #1 Posted January 28, 2012 Well after looking at a few other members versions of the Rock Shaft I took what I had and made my own. I went at this at a slightly different angle than I had seen others make them. I started out with a 6" long piece of 1" dia. stock (a drop off a 1" DME core pin (Nice and HARD)). I turned the ends down to 7/8"dia. about 3/8" back on both ends. I then took 2 1" steel bushings and sandwiched between them a piece of 1/4" x 1 1/2" flat stock and welded it all together. Instead of having the shaft turn in bushings in the tractor frame the shaft locks into place between the frame and the bushings pivot the arm instead. I don't know if this is better or worse than anything else I have seen but it looks like it should serve my purpose just fine. What I am pondering is whether or not I really need to lock in the position of the arm on the shaft or would it be just fine to let it float on the shaft. Whatever implement I would have on it would keep it in alignment and when nothing is attached does it really matter if it floats on the shaft. If I need to lock it into place I could cut grooves in the shaft for retainer rings. I still need to put the holes in the arm for attaching to the cable and the chain but I want to put it into position so I can figure exactly where they need to be. Attached are some pics of what I've got so let me know what ya think. I am always looking for ways to make stuff better so any input ya have is appreciated. Share this post Link to post Share on other sites
sorekiwi 761 #2 Posted January 28, 2012 Nice! You could use a couple of shaft collars to keep the arm in place of the shaft. Easily adjustable, and you dont need to pull the shaft back out for machining of circlip grooves. Share this post Link to post Share on other sites
AMC RULES 37,235 #3 Posted January 28, 2012 Really nice work Paul. Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #4 Posted January 28, 2012 Nice work! Will you be securing the pivot shaft so it won't turn in the fender support? I can measure the hole spacing on an OEM bellcrank if it will help. :confusion-shrug: Share this post Link to post Share on other sites
Paul D. 26 #5 Posted January 28, 2012 I would love the measurements for the hole spacings. When I install it it should be squeezed between the fender supports which should keep it from turning. The arm actually turns very easily on the shaft so I don't think it will be an issue. Share this post Link to post Share on other sites
zieg72 209 #6 Posted January 28, 2012 Nice piece of craftsmanship 1 Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #7 Posted January 28, 2012 I would love the measurements for the hole spacings. Measurements are center to center: 4 1/8" from pivot shaft to the pin where the chain attaches and 6 1/4" to the cable trunnion. Share this post Link to post Share on other sites
Paul D. 26 #8 Posted January 28, 2012 I would love the measurements for the hole spacings. Measurements are center to center: 4 1/8" from pivot shaft to the pin where the chain attaches and 6 1/4" to the cable trunnion. Thanks Terry Share this post Link to post Share on other sites
Paul D. 26 #9 Posted January 28, 2012 Can anyone unlock the mystery of how long that cable should be? Its for a C141 if that makes a difference I would assume it would Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #10 Posted January 29, 2012 The overall length of the cable I have is roughly 20 1/4" - not including the clevis. The clevis adds about another 1 3/4" This illustrated parts list for the 85514 clevis hitch kit might help you too. Share this post Link to post Share on other sites
Paul D. 26 #11 Posted January 29, 2012 Thanks again Terry. I will get this thing whipped yet. I just can't get over how willing folks are to help here on the square :beer: Share this post Link to post Share on other sites
wh-jason 33 #12 Posted January 30, 2012 thanks for the great idea guys. mine isnt as nice as yours paul, but i think it will work just fine. here is what i came up with today and installed 1 Share this post Link to post Share on other sites
Paul D. 26 #13 Posted January 31, 2012 Should work great Jason! Share this post Link to post Share on other sites
