Prater 77 #1 Posted January 24, 2012 The drain plug hex socket was stripped on the D transaxle. I used an easy out to remove it but need a replacement plug, is it a standard thread or something special that I need? The threads in the transaxle are not damaged. Thanks Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #2 Posted January 24, 2012 It's regular pipe thread..... 1/4", I believe. :scratchead: Share this post Link to post Share on other sites
Hodge71 691 #3 Posted January 24, 2012 1/4 NPT is correct sir!!! Share this post Link to post Share on other sites
Prater 77 #4 Posted January 24, 2012 Thanks guys, thats what I thought. Share this post Link to post Share on other sites
gogolito 0 #5 Posted February 10, 2013 hello i have 516 h same problem with drain plug hex is it the same thred thx Share this post Link to post Share on other sites
groundhog47 445 #6 Posted February 10, 2013 (edited) hello i have 516 h same problem with drain plug hex is it the same thred thx Hello, gogo... : :to Some one back had apost on this will see if can find it, be back. Ok go back to main page, in upper right section type in drain plug stripped, make sure it shows forums in dark area, pick search. All PM's with that topic or wording come up, unless you already found that out, good huntin' Edited February 10, 2013 by groundhog47 Share this post Link to post Share on other sites
stevasaurus 23,565 #7 Posted February 10, 2013 It probably is the same size and thread...plugs are available at ACE Hardware, Tractor Supply Co....just make sure it is a NPT (pipe thread). Welcome to Red Square. Share this post Link to post Share on other sites
