gipster 1 #1 Posted January 22, 2012 Hi all, Mt c175 wouldn't turn over yesterday. The starter would spin, but it wouldn't engage the flywheel. I finally got it to start, but i had to run the starter for a while before it would engage. Is this a common problem? Any help would be greatly appreciated. thanks jim Share this post Link to post Share on other sites
smoreau 658 #2 Posted January 22, 2012 The treads on the Bendix drive will cause it to freeze up on cold whether.One of mine did the same thing yesterday. You can remove the blower housing or remove the starter, witch ever is easier for you. clean up the threads on the bendix drive and ad some graphite lube. not grease! that should take care of the problem. Also the KT17 likes to ware out the output bushing on the starter. There is a aftermarket kit made by a foren company in taiwan part #26-9218 that is a bushing kit and starter brushes for around $16. I have installed two of these in my Kohler starters with great luck. Share this post Link to post Share on other sites
gipster 1 #3 Posted January 22, 2012 Thanks for the info. Any idea as to the company name in taiwan? jim Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #4 Posted January 22, 2012 That kit is sold by Rotary Corporation as P/N 9218 LINK to an online seller. Share this post Link to post Share on other sites
mdn1081 1 #5 Posted February 7, 2012 smoreau is absolutely right. Had the same thing happen to my Kt17. Cleaned up the starter there a bit and works great. Share this post Link to post Share on other sites
smoreau 658 #6 Posted February 7, 2012 Glad that took care of it. I have fixed 3 starters with those kits so far. Share this post Link to post Share on other sites
