jdpuller 3 #1 Posted January 17, 2012 our 16 hp puller was running good but we wanted a little more umph, so I thought I would tear it down and put in a 18hp cam and freshin it up a little. I took the head off and found some scoring on the cylinder this cant be good. then pulled the pan and to our supprise there was a bunch of big metal pieces floating around down there. turns out both of the skirts were busted off of the piston. everything else looks ok. I ordered a new rod,piston and cam today once they arive we will be off to the machine shop. here are some pictures. Share this post Link to post Share on other sites
Rooster 192 #2 Posted January 17, 2012 ANy Idea what caused the damage? Share this post Link to post Share on other sites
rmaynard 17,082 #3 Posted January 17, 2012 I've heard of piston slap, but that is ridiculous. :scratchead: Share this post Link to post Share on other sites
AMC RULES 37,256 #4 Posted January 17, 2012 It's crazy to think it still ran good like that? :confusion-confused: Share this post Link to post Share on other sites
shallowwatersailor 3,220 #5 Posted January 17, 2012 Takes a licking - keeps on ticking! :wh: Share this post Link to post Share on other sites
jdpuller 3 #6 Posted January 17, 2012 I was shocked. I did not do a compression test because it ran fine started right up and pulled good only reason we tore it down was to put a diffrent cam in and freshen it up. I just hope .030 will get the cylinder cleaned up if not I guess we cheat and if they want to pull the head off and check us out we will put it on the trailer. Our main club has very little rules for the stock class our secondary club can be sticklers but I have yet to see them open a engine up. Share this post Link to post Share on other sites
can whlvr 994 #7 Posted January 17, 2012 ive heard the 16,s are prone to this,one guy told me the only thing left of his piston was the connecting pin,every thing below that was in the crank Share this post Link to post Share on other sites
