dodge78 94 #1 Posted January 14, 2012 I had little faith in it when I ordered it and it did not disappoint. The main concern was can I get the fuel line connector out when it breaks and are there replacement parts. I called them and they said yes on both accounts. They even sent me a pdf file of the instructions because I did not want to open the package incase I wanted to send it back. I should have sent it back. After I had it installed and was putting the fuel line (brand new soft plyable hose) from the pump to the carb, (thats why I said when and not if it breaks) it broke. I have had 20 year old car engine plastic parts put up more of a fight. How am I suppose to feel confident this thing is not going to break when it gets cold, it was only 16 degrees out when I did this. The parts were in the house until I started and then were outside maybe 1/2 an hour before this happened. For the amount of money this pile was .... I need to find a source for a rebuild kit of the old pump. TT-5100_IINon-MetallicBodiedFuelPumpKit_REVISED4_1112.pdf Share this post Link to post Share on other sites
AMC RULES 37,254 #2 Posted January 14, 2012 Not sure I understand how it broke? :scratchead: Share this post Link to post Share on other sites
smoreau 658 #3 Posted January 14, 2012 I agree with Craig, I have several of the new plastic pumps and never had a problem yet. Share this post Link to post Share on other sites
Rollerman 290 #4 Posted January 14, 2012 I had little faith in it when I ordered it and it did not disappoint. The main concern was can I get the fuel line connector out when it breaks and are there replacement parts. I called them and they said yes on both accounts. They even sent me a pdf file of the instructions because I did not want to open the package incase I wanted to send it back. I should have sent it back. After I had it installed and was putting the fuel line (brand new soft plyable hose) from the pump to the carb, (thats why I said when and not if it breaks) it broke. I have had 20 year old car engine plastic parts put up more of a fight. How am I suppose to feel confident this thing is not going to break when it gets cold, it was only 16 degrees out when I did this. The parts were in the house until I started and then were outside maybe 1/2 an hour before this happened. For the amount of money this pile was .... I need to find a source for a rebuild kit of the old pump. I believe a member here sells rebuild kits "Buckrancher"?, also in the pinned links section there is a place that sells a rebuild kit for half of the cost of the plastic replacements. Share this post Link to post Share on other sites
KC9KAS 4,746 #5 Posted January 15, 2012 From the instructions, I think you will have to use the retaining ring to depress the 2 flat tabs to release the (broken) fitting. You will probably need to use a needle nose pliers to help remove the broken fitting. Share this post Link to post Share on other sites
rmaynard 16,836 #6 Posted January 15, 2012 I think Brian (buckrancher) only sells the diaphragms for the vacuum type pumps. Share this post Link to post Share on other sites
buckrancher 2,695 #7 Posted January 15, 2012 http://www.maritimedragracing.com/antique_auto_parts_cellar.htm click on the kohler fuel pump repair tab I make the diapharm for the vacuum pulse style pump Brian Share this post Link to post Share on other sites
tunahead72 2,600 #8 Posted January 15, 2012 dodge78, I'm not a big fan of these plastic pumps either, but I've only ever installed just one. No particular problems installing it, but it did feel flimsy. I did notice after more than a full season of use that it was leaking from the outlet. Turns out I had cut the fuel line from the outlet to the carb just a tad too long, and it was putting pressure on the pump outlet fitting. I cut off a small piece of that section of line and reinstalled it, and the good news is that I haven't had any problems with it since then. Without having the pump in front of me to look at, and assuming you can find a replacement, I think KC9KAS' advice for removing the broken fitting is right on. Take your time, maybe find a warmer place to work (I know MY hands don't function well at 16 deg.). Good luck! Share this post Link to post Share on other sites
dodge78 94 #9 Posted January 15, 2012 http://www.maritimed...arts_cellar.htm click on the kohler fuel pump repair tab I make the diapharm for the vacuum pulse style pump Brian Kit AC-4-S looks like the diaphram I need. Not sure I understand how it broke? I am not sure why it broke either. It may have been a cold injection where the mold or plastic was not warn enough? I only used two fingers and a thumb to move the hose. I did not look at the connector because I was pissed because I needed the tractor. I did notice after more than a full season of use that it was leaking from the outlet. Turns out I had cut the fuel line from the outlet to the carb just a tad too long, and it was putting pressure on the pump outlet fitting. I cut off a small piece of that section of line and reinstalled it, and the good news is that I haven't had any problems with it since then. Without having the pump in front of me to look at, and assuming you can find a replacement, I think KC9KAS' advice for removing the broken fitting is right on. Take your time, maybe find a warmer place to work (I know MY hands don't function well at 16 deg.). Good luck! I had thought of putting the connectors at an angle towards the aircleaner to make the hose longer but thought it might leak. Share this post Link to post Share on other sites
dodge78 94 #10 Posted January 18, 2012 I have the part numbers for the connectors 3/16 90 2529412 3/16 45 2529408 1/4 90 2529411 I also found 1/4 straight 2529409 I will see who has what around town. And the big news is that I won a rebuild kit for the original pump on ebay. Should be here about thursday. It cost about $175 but it was in a lot with about $800 worth of stuff, so be looking for some cheap stuff for sale soon. Share this post Link to post Share on other sites
