specialwheelhorse 174 #26 Posted January 11, 2012 Whatever you do don't EVER under any circumstance put an engine together without using plastiguage to check clearance on rod and journal. More than once. Jim Share this post Link to post Share on other sites
Cole 25 #27 Posted January 12, 2012 my mistake i was overeacting, the engine was probally running about 3800 rpm when my dad was adjusting the carb, when i looked at the rod the journal didnt have scratches would running 3800 make the crank be junk, and i dont know if i already told you guys this but when the engines running, the knock comes and goes, as i said, i will be taking the engine apart within the nextt 2 weeks. Share this post Link to post Share on other sites
AMC RULES 37,254 #28 Posted January 12, 2012 Hey Cole, I think the guys are saying to take the battery out, and hide the key from yourself before it's too late. :scratchead: 1 Share this post Link to post Share on other sites
Cole 25 #29 Posted January 12, 2012 i finally found my surgery date, this weekend, i have baught a used crank for my engine on ebay so if i need one im ready, i baught it for $20.00 so if its junk, i didnt really get screwed. funny craig. Share this post Link to post Share on other sites
Docwheelhorse 2,847 #30 Posted January 12, 2012 Why would you buy a used crank on ebay for $20 when the chances are it will need machining too? Like I said.... you need to STOP and EXAMINE what you have and what you have done..... something was put together wrong right from the start. You sound like your guessing and spending good money after bad. I appreciate you are trying to learn, print the Kohler manual and sit and read through it. The reason the knock comes and goes is because as the crank spins the rod changes direction (piston goes up and down) The knock is the slop being taken up when the rod goes from pulling the piston down and then switches and goes to pushing it back up.. You will get a knock in both directions and it will vary based on speed and load. Tony Share this post Link to post Share on other sites
Cole 25 #31 Posted January 12, 2012 i have printed and read the whole manual already and it says that the crankcase oil level is low, or there is an excessive load on the engine and i dont have a big load on the engine and i used two quarts of oil just like the manual says, and the dipstick reads full so theres something wrong with the inside, and i will be informing you guys about it on friday. Share this post Link to post Share on other sites
Callen 64 #32 Posted January 12, 2012 I would check your piston to cylinder clearance too. Chances are good that the oversize rod beat your crank out of round. Share this post Link to post Share on other sites
Rollerman 290 #33 Posted January 13, 2012 i have printed and read the whole manual already and it says that the crankcase oil level is low, or there is an excessive load on the engine and i dont have a big load on the engine and i used two quarts of oil just like the manual says, and the dipstick reads full so theres something wrong with the inside, and i will be informing you guys about it on saturday. This manual? Share this post Link to post Share on other sites
rmaynard 16,836 #34 Posted January 13, 2012 ...so there's something wrong with the inside, and I will be informing you guys about it on Saturday. This is what we have been telling you. You have to take the head off, and the oil pan off. Then you can remove the piston and connecting rod. Then you need to do the following: Unless you want to take the engine apart to remove the crankshaft, just take the block with the crankshaft in it to a machine shop. Take the piston and connecting rod to the same shop. Take the Kohler K-Series Manual with you. (Any good shop should have a specifications chart, but just in case.) Have the crankshaft journal measured for size and out of round. Have the inside of the connecting rod measured for size and out of round. Have to cylinder measured for bore, out of round, and taper. Have the piston measured for diameter, and out of round. A good shop technician should be able to tell you what is the cause of the knocking after taking the measurements. Be prepared to pay for the measurements. My local shop charges $25.00 for the service, but will apply it to the final bill. Some will do it for free if they are sure they will get the work later. Share this post Link to post Share on other sites
can whlvr 994 #35 Posted January 13, 2012 my guys dont charge for measuring if you get a bore done,but they are pricey compared to some of the prices you guys pay,i paid 150.00 for bore,turn crank,measure everything Share this post Link to post Share on other sites
Cole 25 #36 Posted January 13, 2012 yes that manual, sounds good after i get the engine all apart and cleaned i will be taking the following to the machine shop, piston, rod, block, crank Share this post Link to post Share on other sites
Cole 25 #37 Posted January 13, 2012 hey guys, I started tearing down engine today, what I have found is there is a plastic govenor gear, when I checked it it seems to have a lot of up and down play, the shaft for it is a 3/8 drill rod, are they supposed to be loose like this, if not should I replace it with a steel gear or another plastic, as i spin it it sounds like the knock, could this be the culprit??? Share this post Link to post Share on other sites
Cole 25 #38 Posted January 13, 2012 got the crank to a machine shop and they said it was .005 out of round, yep you guys were right so now im gonna see if the crank i got on ebay is any good and if so, it will be used, im still wandering about the play in the governor gear if thats some of the knock or if its perfectly normal. Share this post Link to post Share on other sites
Cole 25 #39 Posted January 13, 2012 i think i found the tick, could it be the automatic compression release weights that are making this sound? i have already confirmed its not an exhaust leak. Share this post Link to post Share on other sites
can whlvr 994 #40 Posted January 13, 2012 so i have a 12 hpthat im putting together and my governon gear is snug on the shaft,being a part that turns on the cam it would have to within tolorances so it doesnt wobble and finally blow apart,brian millers site has steel or plastic,and i didnt look but the plastic may be still avaiable from kohler,sorry about the crank,sounds like a 10under rod needed and crank turned to match,so i looked and the .005 is right on the edge,thats the # in the manual,but its apart now,i know sometimes engine rebuilding can be a little frustrating when you dont do it often(like me) Share this post Link to post Share on other sites
Cole 25 #41 Posted January 14, 2012 thanks for the info i will be purchasing a new cast iron gov. gear, does anyone know about the ACR flyweight ticking or would it be easier to just take them off? Share this post Link to post Share on other sites
rmaynard 16,836 #42 Posted January 14, 2012 ...does anyone know about the ACR flyweight ticking or would it be easier to just take them off? Don't take them off. Starting will be a lot harder. Ticking is normal when turning the crank by hand. Once the engine reaches 300 rpm, centrifugal force holds them out and the clicking stops . Share this post Link to post Share on other sites
Cole 25 #43 Posted January 14, 2012 ok so when i get the engine running with the new gov. gear that means that hopefully this engine wont tick or knock and will sound perfect, just like yours. :) Share this post Link to post Share on other sites
rmaynard 16,836 #44 Posted January 14, 2012 ok so when i get the engine running with the new gov. gear that means that hopefully this engine wont tick or knock and will sound perfect, just like yours. Every Kohler K-series has a little internal noise. That is unavoidable. But there should be no banging or knocking with properly machined and fitted parts. That includes your governor gear, cam, rod, piston, valves, guides and crankshaft. Share this post Link to post Share on other sites
buckrancher 2,695 #45 Posted January 14, 2012 you do realize the max rpm on a kohler k 6hp and larger engine is not to exceed 3600 Share this post Link to post Share on other sites
Cole 25 #46 Posted January 14, 2012 ok, yes i do realize the max rpm is 3600. Share this post Link to post Share on other sites
Cole 25 #47 Posted January 22, 2012 thank you guys, i got the engine all put back togather today figured out the tick, it was where the tappets where worn down where the valves ride there was a ridge, so i gapped the valves by the gap between the camshaft and the tappets and that was it, then i fixed the crank, turns out the guy that had this before me had the crank turned .010 and i didnt know this and i first baught a standard rod in the rebuild kit put it in,and you guessed it, beat the crank out of round, soooooo, last week had the crank taken to a machine shop with the service manual and had the crank taken down .020 for 40 bucks and he even was nice enough to polish where the seals ride for free. now i currently have a new $50.00 .020 rod in it, the engine has not ticking or knock, FINALLY so now i have the gov. spring in the original holes where the engine ran perfect before the rebuild and the gov. will take the engine like i am moving the throttle up and down but im not, the throttle cable is also adjusted right. what else could be causing this, i just hope its not something internal after i had the engine all apart. maybe its the new gov. gear i baught because the old one was plastic and was worn down, but the new gear came straight from kohler. i just dont know. Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #48 Posted January 22, 2012 You have the Kohler service manual, correct? "Resetting" the governor lever and adjusting the carburetor would be a good place to start. Share this post Link to post Share on other sites
Cole 25 #49 Posted January 22, 2012 yes i have the kohler service manual, i just reread it on how to set the gov. paddle (lever) and that was the problem, thank you everyone on redsquare with helping me get through this rebuild, it took some drama but now i can enjoy it, i will be posting a video and pics of the engine running today. Share this post Link to post Share on other sites
Cole 25 #50 Posted January 22, 2012 well here are some pics of the .020 shaft and a video of it running. http://s1092.photobu...nt=MOV04520.mp4 Share this post Link to post Share on other sites
