gottawh 0 #1 Posted December 17, 2011 After restoring my c141, the battery has been dead. After charging the battery, it starts fine but the ammeter reads negative and after using the tractor it will not restart unless I charge the battery. Any idea's? Share this post Link to post Share on other sites
can whlvr 994 #2 Posted December 17, 2011 the very first place to look is your grounds,especially the recifier ground,it is common for it to go bad,check that your battery cables are clean and tight,if that doesnt work you are gonna need a volt meter to check if you are getting the proper voltage,which you will have to post again and someone will help you out Share this post Link to post Share on other sites
gottawh 0 #3 Posted December 17, 2011 found a bad wire connection at switch. thought that would fix problem. not so lucky. used the kohler trouble shooting guide to learn that the rectifier is bad. Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #4 Posted December 17, 2011 Was it charging prior to the restoration? Share this post Link to post Share on other sites
gottawh 0 #5 Posted December 18, 2011 I thought it had a bad battery so I blamed low voltage on the battery. This explains a lot. Share this post Link to post Share on other sites
