Zeek 2,299 #1 Posted December 13, 2011 Will aJohn Deere 212 Tractor Kohler K301 12hp Engine Flywheel Screen fit a Kohler 12hp K301 on a Raider 12? They look similar. Is a K301 a K301 or are there differences between a JD and WH version? Thanks! Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #2 Posted December 14, 2011 The bolt pattern is normally the same, but spacers may be needed to keep the screen from rubbing the blower housing. There are definitely differences between the engines (hence the need for different spec numbers) but you should be OK with the flywheel screen. Share this post Link to post Share on other sites
Zeek 2,299 #3 Posted December 14, 2011 Thanks for the info TT. Share this post Link to post Share on other sites
