Riley088 63 #1 Posted December 11, 2011 Sitting on the tractor with the wheels straight is there a certain side I punch the roll pin through or does it not matter? Thanks R Share this post Link to post Share on other sites
Kelly 1,033 #2 Posted December 11, 2011 no what ever side is easy to get to, it is a straight hole, with the old metal center wheels I use heat if it does not come right out. Share this post Link to post Share on other sites
Riley088 63 #3 Posted December 11, 2011 Thanks should be fun. Share this post Link to post Share on other sites
Riley088 63 #4 Posted December 11, 2011 After using some heat on the roll pin any suggestions on taking off the steering wheel with out destroying it? Share this post Link to post Share on other sites
Kelly 1,033 #5 Posted December 11, 2011 A 3 arm puller and heat, or drill the shaft out till it comes out of the wheel, the shaft is just 3/4" bar stock with a roll pin hole on both ends. Share this post Link to post Share on other sites
VinsRJ 723 #6 Posted December 13, 2011 One thing I like to do, if replacing the steering shaft is required, is to drill the roll pin hole in such a position that the steering wheel spokes are at the 2, 6 and 10 o'clock positions with the front wheel pointing staight. it always looked wierd to me with the spokes in any other position. Share this post Link to post Share on other sites
clintonnut 127 #7 Posted December 14, 2011 Cut the shaft off, put on the drill press and drill away just dont go all the way through. Start with a 1/4" bit and work up from there. You will know when you hit the bottom of the hole as there will be a gap between the shaft and the steering wheel. Try to get the roll pin out first. Charlie Share this post Link to post Share on other sites
