fourwheels0
1975 c-120 special ?
fourwheels0
besides the engine is there any difference in the 1975 c-120 with a kohler and a 1975 c-120 special with a techy (ssi ignition).
is the electrical system the same.
rmaynard
If you check the parts cross-reference, the wiring harness is the same as for the Kohler C-120's. I didn't check all the other parts. I'll leave that to you.
fourwheels0
ok thanks.
i looked around and from what i see everything seems to be the same except the engine.
thanks again.
TT
I beg to differ.......
Model 1-0357 Wiring Harness-104075 Regulator-Rectifier (10 Amp)-104075 Ignition Switch-103991
Model 1-0375 Wiring Harness-104704 Regulator-Rectifier (20 Amp)-104816 Ignition Switch-103991
Model 1-0395 Wiring Harness-104703 Regulator-Rectifier (15 Amp)-101450 Ignition Switch-103990
Model 1-0396 Wiring Harness-104703 Regulator-Rectifier (15 Amp)-101450 Ignition Switch-103990
Kohlers are battery ignition & the Tecumsehs have SSI (ground the coil to kill the spark)
If you know what you're doing, you can change the ignition switch and "move a few wires around" so you don't have to replace the entire harness.
fourwheels0
thanks terry.
i think i'll pass on the tractor. looks like more than i'd like to deal with.
i hate wiring.
rmaynard
Pardon my ignorance again. :bow-blue: First glance at the parts list on SEPW for all four models showed the 104703 wiring harness, I looked no further.
rwilson
I dont see anything different besides the motor and wireing harness. What is wrong with the one you are considdering?
fourwheels0
it has a techy motor in it and i don't like or trust those motors.
after finding a 12hp kohler and rewiring i'd have too much money in it.
Trouty56
I saw a C-160 with a techy in it and the engine was taller than a kohler. To accommodate it there was a taller mount at the front hood hinge and apparently the steering stand was higher also. Looked cool so I tried to use the front hood mounts on my C-160 to raise it but the hood would not fit correctly at the steering stand. Bummer!!
