Countdown To Christmas!
buckrancher
A tale of two Horses
buckrancher
Some times life kicks your feet out from under you and you lose everything
that happened to many people this year with the great flood of 2011 in southern New york when the
mighty susquehanna river rose 48 feet
This is a story of healing and redemption for two old horses that found themselves 10 feet under water
I acquired these tractors from snyder's fix-it shop in Endicot, NY and hopfully I will have them both up and running by next spring
my god it looked like a bomb went off inside the building
RJ35
RJ35
854
854
loading up the ride home
Brian
smoreau
I know there in good hands Know Brian :thumbs:
HorseFixer
Instantly they will be turned to Stainless! :) Nice haul Brian, :bow-blue: I heard you recued those with a Submarine! :ychain:
~Duke
perry
yep, in good hands now . nice save
JimD
You'll have them in fine shape by spring Brian. :handgestures-thumbup:
dclarke
Nice haul Brian! :thumbs:
VinsRJ
Very nice haul Brian..... Darn, that RJ looks complete!
Stigian
Nice rescue Brian, any idea how much damage the water has done to them?
rmaynard
Brian,
If anyone can bring these horses back it's you. Anxious to see what kind of magic the "man of stainless steel" can do.
Bob
PM Sent
Suburban 550
Nice haul and a great save, Brian. Sure wouldn't mind ownin' that 854. If you ever want to part with it, I wouldn't mind given' it a new home. Went through that same flood up at the campground in September and got to see the devastation it left behind, fortunately I was one of the lucky ones.
buckrancher
First stop was at the car wash with a bag of quarters
then on to my work place to unload I'm lucky that I can use the shop for tractor stuff
854 after bath
RJ35 after bath
this also came along for the ride an original noise weight
Brian
varosd
wow! they look like they were in great condition, pre-flood, at least you are starting out with good equipment. Can you start a work in progress thread? good luck and hats off to you for saving them from someone just throwing them into the crap heap!
KC9KAS
Looks like they cleaned up pretty good.
I guess you will have to tear down the transmissions & engines to clean out the mud.
Actually maybe you can get by with just flushing them with kerosene several times then use an oil flush.
buckrancher
It's my understanding that this was the second time both of these tractors were under water
five years before there was another flood in that area neither of them were ever started
up afterward just drained and not an overly great job of doing that. The 854 engine was seized up
the RJ engine would turn over by hand but the recoil was not working.
Brian
JC 1965
They look really good now. I know you still have engine and trans work ahead, I hope they're isn't too much damage. Good luck with it. Sure would like to see them when they're all finished. :eusa-whistle:
AMC RULES
I bet the mold in the building they came out of is deadly to humans. Hard to believe the Horses survived in such good shape. Two beautiful machines, you were definitely in the right place at the right time that day.
stevebo
Brian,
I would love to find an 854 like that... Good luck with them.
Martin
so brian, now that these two are cleaned up a bit, can you see damage done to them. you mentioned that one of the engines are seized, but is there much rust that you can see anywhere? looks like they both have a decent amount of paint on them, im suprised they look as good as they do, considering this is the second time underwater and there has been 5 years between 'bathing'......
buckrancher
Yes had we been there for a couple of hours we would have been wearing masks the mud that covered everything is toxic
(raw sewage ,feul oil etc). this was a in and out job but you still get it all over yourself it's just like talcum powder
and it's every where and in everything
Brian
speedyleedy
:) :) good find brian, i think you should have no problem bringing them back to life !
buckrancher
First order of business is to remove and tear down both engines the 854 engine was stuck
but not as bad as I first thought the starter generator was froze solid so once it was removed
I added some oil in the cylinder and was able work the piston up and down with the flywheel
854 piston and rings corroded to each other
quick clean out of the S/G
armature cleaned up
brush springs were rusted in two
float hinge rotted off
all parts were checked and mic'ed for wear
The parts I bought to replace are:
.01 oversize piston and rings( and bore cylinder .01 oversize)
STD rod
crankshaft bearings&gasket kit
intake & exhaust valves
carburator float & rebuild Kit
fuel pump (one on motor was missing check valves)
starter/generator rebuild Kit
air filter
tune up kit
also had too replace the check valve on the inner valve cover plate
Brian
buckrancher
RJ35 engine
mud inside flywheel cover
parts all cleaned and checked for size
after checking all parts I see that I will need to bore engine oversize and replace the crankshaft,
rod ,crank bearings ,piston rings and a valve job,carb.rebuild kit, tune up
now comes the hard part finding all the motor parts . :eusa-doh: I have some of them
But if anyone has a Clinton NOS crankshaft (12100/46-207) they would like to sell or trade for
a NOS crankshaft for a Clinton B1290 (12132/46-239) please send me a PM
Brian
stevebo
Charlie is your man for clinton parts.
MikesRJ
Looking good so far Brian. :notworthy:
buckrancher
after taking both motors apart and it's going to take some time to find the parts for the clinton
I'm going to finish the 854 first
motor rebuilt and back together
then on to the transmission
replaced both axle needle bearings
all seals and one axle shaft
shift boot
Brian
