71_Bronco 1,073 #1 Posted November 30, 2011 I tried doing a search, and looked through this forum, and found nothing. So are Hydro's any good for pulling? Or is it generally better to have a stick so you can change your gear, as well as your pulley sizes & ratios? Thanks Share this post Link to post Share on other sites
Jim_M 179 #2 Posted November 30, 2011 I've seen guys try it with a hydro, but none of them ever did a thing. A kid tried a hydro Cub in my class last fall and couldn't even move the sled. Share this post Link to post Share on other sites
Big Jake 18 #3 Posted November 30, 2011 It takes more hp But I pulled a Ford 145 hydro. last year and did ok. But the Ford had hi - low rear I pulled in the stock class Jake Share this post Link to post Share on other sites
71_Bronco 1,073 #4 Posted December 1, 2011 Thanks guys. Was thinking about doing a little pulling with my Bronco 14 possibly in a stock class after its all restored, but based on this, I think that wouldn't be a great idea lol. Thanks! Share this post Link to post Share on other sites
buckeye25 0 #5 Posted February 2, 2012 i havent found many wheel horse hydros tha thold up under severe duty for very long especialy while pulling 10 foot 30 inch logs from the woods :eusa-think: Share this post Link to post Share on other sites
stephan07 10 #6 Posted March 24, 2012 used a c145 hydro before leave a lot to be desired. 8 spd would be the way to go if you wanted to pull Share this post Link to post Share on other sites
Rideawaysenior 28 #7 Posted April 11, 2012 It all depends. Hydros can and do indeed pull very well. I had a D160 that pulled 5,000 lbs on a weight sled. To boot, it was stock pulled from a drawbar on the 3point hitch and 300 lbs on the front end of the tractor. I'd say that the Sundstrand pumps are the ones to use, the Eatons have a bypass that is set way too low. I could hardly move a 2,000 sled with my 418-A. Now compare that to an 8 speed with an 8 pinion rear? I'd say there is none. 8 speed is the way to go. Share this post Link to post Share on other sites
