Hydro 131 #1 Posted November 29, 2011 I have a mid mount 50" grader blade which attaches to the rear axle. I believe this is the later version as opposed to the mid mount style connected to the attach a matic. Often even with down pressure the ground suface is very hard. Has anyone on this forum ever considered or designed a removable peg tooth harrow that would mount on the grader blade to rough up the soil then be removed so the loose soil could graded. I have a parking lot full of pot holes and I know my Wheel Horse could do it if only the ground were able to be roughed up first. :idea: Share this post Link to post Share on other sites
dennist 139 #2 Posted November 30, 2011 Sounds like a great idea. Like teeth on a front end loader. Share this post Link to post Share on other sites
MaineDad 87 #3 Posted November 30, 2011 They made a mid mount cultivator that would do just what you need Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #4 Posted November 30, 2011 I had intended on making a tooth bar for my home-built grader blade but it hasn't happened yet. My plan was to weld teeth (railroad spikes ) to a piece of flat steel and set it up so it would clamp up over the bottom edge of the moldboard. I wanted it for breaking up packed & frozen snow / ice from a gravel driveway. I really doubt that cultivator shovels would take the pressure of trying to break hard pan loose - especially when forced by hydraulic downpressure. I have actually seen the standards bend on the OEM cults. :blink: Share this post Link to post Share on other sites
can whlvr 994 #5 Posted November 30, 2011 i have a red neck one that i push and pull on my dozer blade,its a harrow that i hook up to the blade,i have this too but its not on a grader blade this is the ripper,and how i pull it Share this post Link to post Share on other sites
rexman72 210 #6 Posted November 30, 2011 that looks like one mean machine i have a red neck one that i push and pull on my dozer blade,its a harrow that i hook up to the blade,i have this too but its not on a grader blade this is the ripper,and how i pull it Share this post Link to post Share on other sites
Ole MN 11 #7 Posted November 30, 2011 I made a bar out of chanel iron 11" points i got @ country macy's. Attached to my back blade it has about 8 teeth across. All bolted togather (no welder) Its adjustable show more of the tooth or less. used it to break the ground (clay) when i was doing some landscaping. worked ok but no down pressure on my 3pt. finally i broke one of the lift points. I'll have to take a picutre. Share this post Link to post Share on other sites
Hydro 131 #8 Posted November 30, 2011 I'll have to take a picutre. Yes please. Don your Red Neck version is almost what I had in mind. Years ago I once had access to a small set of peg tooth harrows and they used something like a railroad spike, with some weight they worked very well dragged by my IH 149. After trying my grader blade I just know if is capable of more if only I could loosen up the hard packed surface. I wondered whether or not something could be incorporated into a removable cutting edge? so it could be bolted in 3-4 points and no so many spikes that the weight of the blade would penetrate. Can always make several passes. Share this post Link to post Share on other sites
can whlvr 994 #9 Posted December 1, 2011 i see no reason why some 3/4 rebar to a strip of 1/4 plate and like gary said bolted to the grader blade,i found with my old grader (that got stolen)was not real good at ripping too much,even after a rain i found that the wheels spin once you try to dig too much,dragging something behind seemed to work good,but a grader ripper will work i think too,probally not as fast ,some weight on the blade and tractor allways helps,that dually had liquid in the inner wheels,im not sure how much tooth would be allowed,need to lift it some to move around without it hitting too much,you will have to play around with it,the pics arnt really my hill billy setup,i dont have picks of that,its on the front of the tractor,cant lift it its 5x5 feet,but i can push it and pull it,but only on the drive way Share this post Link to post Share on other sites
Hydro 131 #10 Posted December 1, 2011 Don it may be that pulling draws the back end down and gives better traction Share this post Link to post Share on other sites
can whlvr 994 #11 Posted December 2, 2011 ya i think you are right,and the grader lifts on the tractor reducing weight Share this post Link to post Share on other sites
jay in nc 210 #12 Posted December 3, 2011 TT i built a scarifer - drag to rough up the neighbors horse riding ring. i used 12 r.r. spikes arranged in a 30 in. triangle it looked great but he brought it back in 3 weeks because the spikes kept bending & then breaking off.right below the welds. i fixed it by replacing the spikes with 4 in pieces of pipe with form board stakes w. a cotter pin above & below the pipe to hold the stakes. the r.r. spikes are too brittle to stand up to side force. but the idea of a scarifer for the blade is a sound idea. Share this post Link to post Share on other sites
Hydro 131 #13 Posted December 5, 2011 Thanks Jay, I would like to try to build something for next spring. Share this post Link to post Share on other sites
ce318 13 #14 Posted December 14, 2011 I used a JD road grader on Mt Hood in Oregon that had serrated teeth on the cutting edge of the molboard, this was designed to cut snow pak off the roads. A typical set of bits would last a week, with the JD bits (serrated) we could go a month and this was 3, 8 hour shifts 7 days a week. Here is my computer rendition of the bit (UUUUUUUUUUUUU) if the U's were upside down and conected between each other you would have a good idea of what I am explaining. the open portion of the upside down (U) is where material breaks up the cutting edge was beveled forward like a single cut edge chissel. Hope that gives you and idea. 1 Share this post Link to post Share on other sites
Rollerman 290 #15 Posted December 15, 2011 I have a mid 60ies short frame "mutt" I've built up useing an 8 speed & some 520 parts. It has a 50" mid mount grader blade on it, I've been toying with the idea of makeing a front mounted ripper for it like the big graders where I work. Share this post Link to post Share on other sites
Hydro 131 #16 Posted December 18, 2011 I was wondering about a piece of channel or two pieces of angle welded together to make a C and then drilling top and bottom to run some type of bar through and then anchor the bars top and bottom. Bolt through the back of the channel to the grader blade in several locations. I think the secret here is to remember what we have for a tractor and also maybe not go too wide. Even if you could loosen 2 inches of soil at a time you would be doing something. Share this post Link to post Share on other sites
