can whlvr 994 #1 Posted November 26, 2011 so the last 2 horses ive picked were newer,1989 414-8 and a 1990 312hydro,any way i noticed that toro changed the clevis,i cant get it to clear the hoop without taking the roll pin out so i put a large hitch pin in so i can take both locking pins(hitch pins)out to take belts on and off,is there a way that im missing without taking the roll pin out,all my other horses have a little dirrerent clevis that clears the hoop when you remove only one locking pin Share this post Link to post Share on other sites
jusjeepn 59 #2 Posted November 26, 2011 Also remove the pin that holds the engagement rod trunion into the linkage that is attached to the top of the bail. This allows all the free movement you need to add PTO powered attachment belts! In short: pull the pin out of the doo-hickey just under the muffler and take off or put on the belt! :dunno: Share this post Link to post Share on other sites
