Prater 77 #1 Posted November 15, 2011 With the weather cooling off and a bit more time in my schedule, I have started back to work on the D180. I was able to replace the coil and fuel pump tonight. Test fired for just a few to keep the neighbors happy. Tomorrow I will start her back up and see if I can get the transaxle moving again. Might be in the market for a new rear end if this donor I have will not work... Share this post Link to post Share on other sites
Prater 77 #2 Posted November 15, 2011 Ran crappy this morning so I picked up new plugs. Now I have no spark after a short run with new plugs. Power to the new coil, just not firing...points needed a cleanup so I took care of that but still no spark. Even the old plugs wont spark, figured I may have blown the new plugs with the Accel coil. What fun this is...ohh and when the engine was running there was no forward or reverse!!! Share this post Link to post Share on other sites
wh79d160 52 #3 Posted November 16, 2011 Might make sure your push valve is closed. Hopefully that is what your forward/reverse issue is. :dunno: Share this post Link to post Share on other sites
Prater 77 #4 Posted November 16, 2011 Thanks, Valve was the first thing I checked... Share this post Link to post Share on other sites
