carlsbarn2 7 #1 Posted November 10, 2011 Which would have more traction for dirt moving ,large 26x12x12 tires or dual wheels with 23x10.50x12 inside and 23x8.50x12 outside.All tires are Tru power lug type. Share this post Link to post Share on other sites
Doubletrouble 10 #2 Posted November 10, 2011 This is just my opinion but I would think the single tires would be better with some wheel weights or some kind of weights added to the rear of the tractor for traction. With duals your weight is spread across 4 tires instead of just 2 so each tire carries less load which means less grip. Share this post Link to post Share on other sites
CasualObserver 3,414 #3 Posted November 10, 2011 "Traction" is a tricky thing. It's a balance between the tractor and the conditions. Personally I'd go with duals and add weight to make up the pounds to the ground difference. Duals will give you better floatation, more surface contact and more stability, but you'll be putting more rubber on the ground, which means the weight of the tractor is spread out more and creates a larger but softer footprint. Adding weight will help offset that. By having a wider stance and more ground contact, especially in soft conditions like dirt, means you have less of a chance of stopping motion if you lose traction in one spot. If you go with the single tire and you get to spinning, you can get dug in pretty quickly. Spreading that out over a larger footprint decreases that risk.....as long as you add weight. Share this post Link to post Share on other sites
wallfish 19,327 #4 Posted November 10, 2011 I used dual 10.5 AGs when I was leveling my backyard and it worked very well for traction in the loose dirt. I did add extra weight too. I don't know if there was too much weight or too much leverage from the duals or a combination of both but the 1 1/8 axle snapped at the deepest part of the woodruff key hole. Share this post Link to post Share on other sites
SAM58 34 #5 Posted November 10, 2011 I used duel 10.5 AGs when I was leveling my backyard and it worked very well for traction in the loose dirt. I did add extra weight too. I don't know if there was too much weight or too much leverage from the duels or a combination of both but the 1 1/8 axle snapped at the deepest part of the woodruff key hole. Like Walfish said... Under heavy load conditions the duals will give you problems, I would go with the 23 x 10.5 x 12's with weights. My .02 :dunno: Share this post Link to post Share on other sites
Sparky-(Admin) 24,643 #6 Posted November 10, 2011 Back when I ran dual Ag's my inner ones were filled with fluid and the outer ones had just air. I think any weight on the outer wheel is askin for a snapped axle. Just my opinion. Mike.......... Share this post Link to post Share on other sites
Ken B 3,202 #7 Posted November 10, 2011 I've used single ags with good results. If you have neither and you have a set of chains, throw them on, they work great also. Share this post Link to post Share on other sites
gcole 36 #8 Posted November 11, 2011 I think the 23x10.5 tru powers will perform well I know this summer I cleared a place on the edge of my forest and the only thing that stopped me was forgotten blocks of wood wedged in holes Share this post Link to post Share on other sites
Retired Wrencher 6,456 #9 Posted November 12, 2011 :dunno: A good set of Ag tires should do the trick. Share this post Link to post Share on other sites
carlsbarn2 7 #10 Posted November 13, 2011 I choose to keep my 10.5x23x12 ags on with 8.50x23x12 ags on outside duel.( my 23x10.50s are soft foam filled approx. 80 lbs. per wheel.I am running less pressure on outside and after using blade today,Im very satisfied.No other weight on tractor.( C-175 ) Share this post Link to post Share on other sites
boatman 3 #11 Posted November 13, 2011 :wh: Hi there, I have a 416-8 with ag tires I use only for working in garden.I have 50lbs of weight on each tire and it does great. I use a mold board plow and also use a disc with a spring tooth hooked on behind disc and never have any trouble pulling them. With the duals the outside wheel puts alot of extra pres on axle and bearing. duals are ok if you need stabilaztion or floatation but without alot of extra weight added, you'll have less lbs per square inch and less traction. :dunno: Share this post Link to post Share on other sites
CRE1992 143 #12 Posted November 13, 2011 My vote = Tru Power 23x10.50x12 No duals. Share this post Link to post Share on other sites
chevrat68 19 #13 Posted November 14, 2011 The only thing a skinny tire works well in is snow to cut down to something sold. Share this post Link to post Share on other sites
