rockbuilt 7 #1 Posted November 9, 2011 I found a 3 point hitch off a D180 I read that this is what I need for my 83 C195 but this one does not have the vertical hydro cyl I don't want to buy something I can't use. if someone has a good pic of a C195 3 point set up it would be Great Thanks in advance Oh by the way it's great to be back Share this post Link to post Share on other sites
stevebo-(Moderator) 8,604 #2 Posted November 9, 2011 Run a search and you should find a very good diagram that brian posted. There are some differences from the D and the C195- Share this post Link to post Share on other sites
Kelly 1,037 #3 Posted November 9, 2011 The D 3 point upper rock shaft is not the same as the 195, but the lower arms and lift links are the same, the lift cyl. is the same but on the d it is under the seat, if it's a good deal buy it, it is at least half the parts or you can resell it. Share this post Link to post Share on other sites
rockbuilt 7 #4 Posted November 9, 2011 it's a good deal but not a steal and what rocker shaft would work or does it have to come from a C195 or be fabricated? Share this post Link to post Share on other sites
Kelly 1,037 #5 Posted November 9, 2011 Has to be a C-195 and you will need the mounting blocks for the rockshaft, I had to have a pair made, they are no longer available from Toro, and also 195 only. Share this post Link to post Share on other sites
htopjimmy26 3 #6 Posted November 11, 2011 I have a brand new rockshaft I bought from a dealer about 2 yrs ago. It may still be available from Toro. Share this post Link to post Share on other sites
