powerhawk56 0 #1 Posted November 7, 2011 Looking for parts for the pictured snowblower. Blower is 30" w X 12" h. Need help identifying model. Parts needed are pulleys and control level (they are missing). If you have parts, know where I can get them please let me know. Any help is appreciated. Thank you. Share this post Link to post Share on other sites
Rollerman 290 #2 Posted November 7, 2011 What you have is an older blower moounted on a later style tractor with the "bell" style PTO. That bracket that hangs off the side...you won't need what was initially there, that for the older tractors that didn't use the same PTO setup as you have. What you do need is the idler pulley & belt tensioner setup that mounts on the blower. PS I fixed your images so they could be viewed. Share this post Link to post Share on other sites
Kelly 1,037 #3 Posted November 7, 2011 I have the idler set up off a newer blower, but will not be a direct fit, as Rollerman said that blower does not go on that tractor, you might just build a idler to take up the slack on the belt make it spring loaded, but if you want the parts I have send me a PM. Kelly Share this post Link to post Share on other sites
powerhawk56 0 #4 Posted November 8, 2011 Thanks for fixing the pictures. I'm pretty much looking for something to make the blower work for this winter. Share this post Link to post Share on other sites
