truckin88 104 #1 Posted November 7, 2011 I just gave my dad my 310-8 and it ran good all year, but it has had an issue, that after releasing the clutch it waits about 10-20 seconds to actually move. The clutch pedal returns normally, just the tires don't go right away. Bad drive belt??? it is a 91 310-8, once moving it works great. This is in all gears. Share this post Link to post Share on other sites
Rollerman 290 #2 Posted November 7, 2011 Check the axle hubs for a loose one? Share this post Link to post Share on other sites
Kelly 1,037 #3 Posted November 7, 2011 You say the pedal returns normal but is this the model with the gas shock instead of the spring for the clutch? I've heard of them going bad and slow acting. Share this post Link to post Share on other sites
truckin88 104 #4 Posted November 7, 2011 there is no gas spring just a regular clutch spring. Share this post Link to post Share on other sites
truckin88 104 #5 Posted November 7, 2011 I have had loose axle hubs and they travel on the shaft which these never have, but I can check they are dual set screw hubs....which would stink since I just sold a set.... Share this post Link to post Share on other sites
Rollerman 290 #6 Posted November 7, 2011 If you don't find a loose hub I would pull the belt guard & check the condition of the belt, idler, spring, & both drive & driven pullies.....the pulley on the traans has been known to come loose just like the hubs can. Share this post Link to post Share on other sites
Irv 115 #7 Posted November 7, 2011 Sounds like the belt may be slipping (probably hard and shiny) til it gets warm and grabs. Share this post Link to post Share on other sites
Kelly 1,037 #8 Posted November 7, 2011 Might be the belt, I have one here that the clutch pulley comes up and hits the belt guard and never does get the belt tight because it is worn out, and I'm pretty sure it is a blue aftermarket belt, OEM belts are best for the drive belt on a 8 speed tractor. Share this post Link to post Share on other sites
