smoreau 658 #1 Posted November 5, 2011 :thanks: 57" blade that I picked up from a RS member that was nice enough to bring it to Kellys Charlotte show was the start of this idea. I wanted to make my favorite worker, my 95 417A, a v blade. Last winter the 48" blade didn't slow it down at all and worked like a charm! My 48" dozer blade is way too nice to cut up, so I looked on CL and came up with a 57" dozer blade for a buck fifty. Then my favorite tool of destruction came out and cut it in half The Saw Zaw The the tape measure and some figures started to run through my head and the two half's came back together with a hinge between them. The blade is know 58 1/2" wide know. I also made the mount for this blade for the A frame and the ware bars, but I forgot my camera last week as I was very busy with the Spook Train thing I do every year driving my 1/3 scale mini around at Junction Vally Railroad. Any how I used a BOSS v blade as a model for this project, and alot of your ?'s will be answered with the next pic's I will take on Sat. More to come........... 5 Share this post Link to post Share on other sites
Gene_S 93 #2 Posted November 5, 2011 This is something I've been wanting to do for years... Thanks for posting the pictures and I will be following this to the finish!!! :wh: Share this post Link to post Share on other sites
KyBlue 655 #3 Posted November 5, 2011 What a great job. Welds look superb too! Look forward to seeing how you finish it up! Share this post Link to post Share on other sites
Sparky-(Admin) 26,206 #4 Posted November 5, 2011 Real nice job ! Lookin forward to seeing it pushing snow. Mike......... Share this post Link to post Share on other sites
Rollerman 291 #5 Posted November 5, 2011 That looks great Scott, will it fold hyd cylinders? Nick in OH built one a few years back & pushed it with a 520LXI, but if I remember it was a mechanically angled? viewtopic.php?f=4&t=1529&hilit=v+blade Anyways slick build & can't wait to see the finished blade mounted up. :dunno: Share this post Link to post Share on other sites
aeallison 1 #6 Posted November 5, 2011 Awesome job. It gives me some great ideas too. As others have said, I cant wait to see how it all works out. Good job. :dunno: Share this post Link to post Share on other sites
Nick 13 #7 Posted November 5, 2011 Very nice work love to see it in action this winter. I had just thrown my manual adjusted V blade together from looking at my brothers Boss plow but also got the idea from the Steiner and Ventrac electric hydraulic adjustable V blades. Both sites have video of the blades. Steiner V plow http://www.steinerturf.com/attachments.asp?c=3&p=5 Ventrac http://ventrac.com/products/attachments/KV552/ I forgot to mention as Scott said those are some nice looking welds. :wh: Share this post Link to post Share on other sites
can whlvr 994 #8 Posted November 5, 2011 lookin good,do you plan to have it like the ventrac or ive seen bobcats with versitile v blades that angle,scoop,and straight,it will be real handy,where are you going to get hydro from,the tractor pump or an auxilery pump unit? Share this post Link to post Share on other sites
rexman72 210 #9 Posted November 6, 2011 scott cant wait to hear how the 417A does with that good looking V plow. Share this post Link to post Share on other sites
smoreau 658 #10 Posted November 6, 2011 :dunno: I got more pics today!! And to answer some ?'s It will be hydraulic cylinders powered by the axle pump. I am going to use 12V hydraulic control valves and momentary switches to control the blade. More on this later on. As for the welds, most look great, but some don't. I should take my time more, but that's nice about steel, I can grind out the bird turds and redo it wright! I try to make them nice where they are seen. Ok for the pics This is the mount for the blade after finishing up the fab work. And with some paint on it Hydraulic cylinders installed, and cutting (wear) plates. And a tip I got from Nick's v blade about sidewalk cracks, the nose has a ramp to prevent me from kissing my XXX's on the wheel when I hit a crack or raised piece of cement. The springs installed I couldn't resist to install it on the tractor to see what it looked like Know I'm waiting for a shipment of fittings and hoses from surplus center. Should be here Wed. or Thur I hope! The next fun part is getting to the return line for the lift valve on the 417A. I need to tie into it for the 2 new valves, and run a new line to the filter. The hoses will have disconnects and a on-off switch under the hood so the valves will not operate when the blade is off. Trying to see what other implements I can make that could use the hydraulic ports that will be up front. Still more to come............ 8 1 Share this post Link to post Share on other sites
Gene_S 93 #11 Posted November 6, 2011 Scott that's beautiful work!!! I think I drooled all over my I-Pad looking at them pictures... :dunno: Share this post Link to post Share on other sites
Rollerman 291 #12 Posted November 6, 2011 Looks great, nice fabwork. I recognise the van in the background too, just don't remmeber it sitting so high. :dunno: Share this post Link to post Share on other sites
smoreau 658 #13 Posted November 6, 2011 Looks great, nice fabwork. I recognise the van in the background too, just don't remmeber it sitting so high. Yah that was a load and a half for the old horse hauler By the way, I did get that devil kohler k301 rebuilt and runs great. I did it for my brother this spring. I do have to pull it back apart and replace the gov. weights must be broken. over revs about 500 rpm with it adjusted in any spot :help: Share this post Link to post Share on other sites
smoreau 658 #14 Posted November 6, 2011 Scott that's beautiful work!!! I think I drooled all over my I-Pad looking at them pictures... I hope it's water proof!! I am really looking forward to some snow this year! 520H with the blower and the 417A with a v blade! edit Oh yah and the 2001 Dodge with the western pro plus 7 1/2' blade with 2 6" wings! Bring it on Mother Nature!! :dunno: Share this post Link to post Share on other sites
Gene_S 93 #15 Posted November 6, 2011 Scott is the hinge all home made or something you bought??? Another question is I've seen a 48, 54 and a 56 (D-series) blade. That's 57 inches??? Share this post Link to post Share on other sites
jay in nc 211 #16 Posted November 6, 2011 nice work on the blade.is that a 2010 or a 1010 in the background? we bought a new 2010 in the fall of 63 but it went with the farm in 73. Share this post Link to post Share on other sites
smoreau 658 #17 Posted November 6, 2011 Scott is the hinge all home made or something you bought??? Another question is I've seen a 48, 54 and a 56 (D-series) blade. That's 57 inches??? I made the hinge with a piece of 3/4" cold rolled bar stock and some 3/4" bushings for 3 point hitches found at TSC. I did cut some of the bushings in half and drilled holes in them so the hinge can be lubed. I also used a cut off wheel to put some groves in the bar stock so the lube can get all the way around the bushing. I am almost positive the blade measured 57" across when I got it. Kelly was there when I got it at the Charlotte Show this year. It looked all original and only had 2 springs on it, Kelly thought it should of had 4. I added 1 1/2" in the hinge, And it know measures 58 1/2" across the entire blade when it's straight. It will be a few days and I will get back to Toms and get the tag off the plow and run the #'s. I know that I only added 1 1/2" to the blade, But I could be wrong :dunno: Share this post Link to post Share on other sites
smoreau 658 #18 Posted November 6, 2011 nice work on the blade.is that a 2010 or a 1010 in the background? we bought a new 2010 in the fall of 63 but it went with the farm in 73. That is a 2010 and Its Toms. (n1defan) Its a nice tractor and gets used for snow plowing and yard work over to Toms. He has a post hole digger, brush hog, back blade, and a box scraper for it. Share this post Link to post Share on other sites
Gene_S 93 #19 Posted November 6, 2011 Oh don't worry about the tag Scott... You have done fabulous work on the blade... I had bought a 1054 54 inch blade to do the same thing your doing but with a lot less planning on my end and didn't know exactly how I was going to do it. Then I went and sold it because my project list is longer then my honey do list... Great job!!! Share this post Link to post Share on other sites
massey 119 #20 Posted November 6, 2011 Man that looks excellent, great work. :dunno: Share this post Link to post Share on other sites
KyBlue 655 #21 Posted November 6, 2011 That is so very SWEET!!! Okay Now you've got me wanting one ... Argh! 1 Share this post Link to post Share on other sites
AMC RULES 37,259 #22 Posted November 6, 2011 Mad fab skills! Hope we get to see an action video posted here once the four letter word starts flyin'. :dunno: Share this post Link to post Share on other sites
rexman72 210 #23 Posted November 6, 2011 scott great work and i am glad your using the 417A.Can you please take pics of the hydraulic ports? Share this post Link to post Share on other sites
smoreau 658 #24 Posted November 8, 2011 :dunno: for all the great comments, and a Up date on the control valves. I decided to use 12 volt electric valves so I didn't have to make complicated remote controls to operate the valves, and so it wouldn't look bad. Don't want a big ugly valve hanging out the side of the tractor They will be mounted in front of the engine, and the ports will go through the bottom of the hood. The valves will be mounted to the hood. This is the best look I could come up with without a lot of extra work in the pluming of the control valves. You know KISS. Any how pics of the valves. Still waiting for the rest of the fittings to get here :help: 2 Share this post Link to post Share on other sites
KyBlue 655 #25 Posted November 8, 2011 Bit by bit and before you know it you'll be out pushing the fluffy white stuff with it! Share this post Link to post Share on other sites
