Aussie 98 #1 Posted November 3, 2011 I want to check the correct connection of the positive battery cable to the starter on my 416-8 with an Onan. When I pulled the tractor down the photos I took and notes I made suggest that the positive lead was connected directly to the starter terminal as per the photos. This doesn't seem to be right and I can't understand how it worked. I think the lead should go to the solenoid terminal like this; I haven't tried to start it yet as there are still a couple of things to finish off, but wanted to check before I fry something. Can anyone help me out? :dunno: Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #2 Posted November 3, 2011 I never looked closely at that arrangement, but I believe the "extra" solenoid is used as a safety relay on the older 520 models. The way it is wired in the first two pictures is actually correct. Share this post Link to post Share on other sites
wallfish 19,079 #3 Posted November 3, 2011 I agree. It does look like the starter has an integrated solenoid/relay attached to it so when it's wired like the first pics, it is actually wired through a solenoid. Share this post Link to post Share on other sites
Aussie 98 #4 Posted November 4, 2011 Thank you both. Yes, it's blinding to me now you point it out wallfish, that the solenoid is mounted on the starter. I was so focused on the stand alone solenoid I couldn't see the obvious! I'll put the lead back where it belongs and hopefully have some photos of a nearly complete running tractor to add to my build thread soon. Thanks again. Share this post Link to post Share on other sites
