fourwheels0 191 #1 Posted October 31, 2011 well my cable was about to break on my 6-6211 snow blower so i tried trimmer string and it works. i used .130 size trimmer string (big thick stuff) and it seems to work very well (I,ve heard to use .095 or bigger string). the .130 fit in the holes on the crank handle like it was made for it . we'll see how it does when the snow starts flying and it's cold. i need to get some #40 roller chain this week to replace my stretched one and i'm all set. Share this post Link to post Share on other sites
can whlvr 994 #2 Posted November 1, 2011 ive read to use the trimmer line too,but wonder how it will work in the extreme cold,might get brittle,worth a try though,doesnt cost much and usually some spare kicking around Share this post Link to post Share on other sites
fourwheels0 191 #3 Posted November 1, 2011 well i did a test with a 3 ft section of it in my freezer with it and set the freezer as cold as it will get. after 6 hrs it's still very flexible and i could not break this stuff. i'll leave it in the freezer overnight and see how flexible it is then. maybe after it's used for a season it may get weak but we'll see. either way i think it's a good temporary or emergency use backup to the original cable. here's a pic how thick this stuff is. it's sitting on a uni-ball pen so you can get a scale how thick it is. Share this post Link to post Share on other sites
rexman72 210 #4 Posted November 1, 2011 thats good to know when my cable breaks i will have something to replace it with. Share this post Link to post Share on other sites
fourwheels0 191 #5 Posted November 1, 2011 well after almost 24 hrs in the freezer it's still just as flexible as before i put it in. it looks like cold freezing temps won't effect this stuff for at least short term use. let's see how it is after a week in there lol. Share this post Link to post Share on other sites
can whlvr 994 #6 Posted November 1, 2011 thats a good test,i might try it on my 30 inch thrower when i rebuild it Share this post Link to post Share on other sites
fourwheels0 191 #7 Posted November 2, 2011 yup freezer was at 7 below 0 for 24 hrs and the stuff did just fine. Share this post Link to post Share on other sites
scifi4all 6 #8 Posted November 3, 2011 I once used some old wash line wire. The green kind with wire wrapped by some flexible coating. It lasted the entire season. :dunno: Share this post Link to post Share on other sites
WheelHorse_of_course 101 #9 Posted November 6, 2011 I used chain on mine! I would have tried the trimmer line had I known about it. :dunno: Share this post Link to post Share on other sites
TT-(Moderator) 1,173 #10 Posted November 6, 2011 I used chain on mine! I would have tried the trimmer line had I known about it. From the closet: viewtopic.php?f=4&t=8019 How's the chain holding up? :wh: Share this post Link to post Share on other sites
m2424j 9 #11 Posted November 13, 2011 That a great Quick fix! Good thinking. Does anyone know if these blower chutes have been modified to turn on gears not cable? Matthew Share this post Link to post Share on other sites
TT-(Moderator) 1,173 #12 Posted November 13, 2011 Does anyone know if these blower chutes have been modified to turn on gears not cable? Wheel Horse actually changed to a worm gear design sometime in the 90's. I converted my cable chute thrower to the newer set-up using all OEM parts: viewtopic.php?f=4&t=7685 Share this post Link to post Share on other sites
m2424j 9 #13 Posted November 14, 2011 That's good info to know. I like to find a chute from a walk behind snowblower that would fit and allow better vertical control. I think I've seen some power controls but I don't need that. :dunno: Share this post Link to post Share on other sites
