Banjo 0 #1 Posted June 23, 2008 I was cleaning and inspecting my new used 1995 520H (200 hours on it) and looked down at the positive battery cable and noticed where it drops down from the battery behind the side metal panel of the tractor, the cable was FLAT on one side. So I moved it carefully away from the metal panel and noticed the wire was BARE for about 2 inches. A few strands of that cable had actually burned off from rubbing! I carefully disconnected it from the positive post of the battery for further inspection. Must have been bouncing around arcing for a while! Lucky it did not weld to the tractor, probably because the metal panel was painted that it did not weld. Since most of the wire is still intact, I taped up the bare section and installed the entire cable into a "liquidtight" flexible conduit that I had laying around. In the first photo below, I have a green line showing the panel where the cable runs behind where the bare section of the cable was. The yellow arrow shows the new liquidtight piece I installed (gray conduit). So the point is, I am surprised to find this at 200 HRS and I recommend you CHECK YOURS TOO! Any thoughts about how this happened? The cable was not really tight either. ... Share this post Link to post Share on other sites
Banjo 0 #2 Posted June 23, 2008 Just had a thought after looking at the pics that maybe that black metal plate gets hot from the engine and melts or degrades the battery cable that kind of sits next to it... Share this post Link to post Share on other sites
kj4kicks 154 #3 Posted June 23, 2008 Thanks for the info ! I'll be sure to check mine out. Share this post Link to post Share on other sites
Sparky-(Admin) 24,594 #4 Posted June 23, 2008 Same here, thanks. Mike........ Share this post Link to post Share on other sites
92Pony 1 #5 Posted June 24, 2008 I'll give mine a look this evening!~ Thanks! Share this post Link to post Share on other sites
Banjo 0 #6 Posted June 28, 2008 Anyone find their cable is bare? Share this post Link to post Share on other sites
Sparky-(Admin) 24,594 #7 Posted June 28, 2008 I followed out the one on my new 416-H and its fine. Thanks for the heads up tho . Mike.......... Share this post Link to post Share on other sites
