118lfd 8 #1 Posted October 16, 2011 Here are some pics of my Lead wheel weights I made. I used some body filler to level them out and Painted them Cast aluminum engine enamel cause it matches the silver exactly. I weighed them and they weigh 75lbs each. I estimated them wrong when I built them as 90lbs each. I might fill the tires for more weight but they worked so good last year we'll see. I just ordered 2 link chains instead of the 4 links I had last year. I rebuilt my receiver hitch cause I wanted it to be a little stronger. I used angle instead of the flat stock for the flange that bolts to the rear attach bracket. I used a piece of angle to support the receiver. The "first Gen" One Share this post Link to post Share on other sites
KC9KAS 4,744 #2 Posted October 16, 2011 The weights and hitch look very nice & strong! What do you pull with the receiver type hitch? Share this post Link to post Share on other sites
118lfd 8 #3 Posted October 16, 2011 The weights and hitch look very nice & strong! What do you pull with the receiver type hitch? Thanks, I plan on using the tractor to move my boat trailer around and pulling a small utility trailer. I also might make a weight bracket that attaches to the hitch. I have plans to build a dump trailer using an electric linear actuator. Share this post Link to post Share on other sites
Retired Wrencher 5,836 #4 Posted October 16, 2011 :thumbs2: if u do not mind how big is the boat and trailer that u are taking about. also very nice job and what are the dimensions on the hitch ???? Gary B....... Share this post Link to post Share on other sites
118lfd 8 #5 Posted October 16, 2011 if u do not mind how big is the boat and trailer that u are taking about. also very nice job and what are the dimensions on the hitch ???? Gary B....... The boat is 24 foot and 6000lbs but I am not moving it with the tractor. I plan on using it to move the trailer empty. Its in my driveway and it is a pain to move with the truck.. once the boat is on is on the trailer it stays put. I think it woould handle it though cause the tongue weight is 500lbs. I will post dimensions in a little bit. Share this post Link to post Share on other sites
118lfd 8 #6 Posted October 16, 2011 Boat... My real passion other than tractors Share this post Link to post Share on other sites
HorseFixer 2,013 #7 Posted October 16, 2011 You need to sail that thing over To Saint Joseph, MI and Pick me up (Ill Buy Lunch) and we can catch some Asian Carp, that our friends for Illinois have let get into the Great Lakes! <_< That is a nice Ship! Oh by the way nice weights and Hitch ~Duke Share this post Link to post Share on other sites
farmer 1,078 #8 Posted October 16, 2011 Nice 118lfd, but like Roy Scheider said "we're gonna need a bigger boat", but in your case.. a bigger tractor :thumbs2: Share this post Link to post Share on other sites
118lfd 8 #9 Posted October 16, 2011 We fish all over but I think Michigan is a little too far a run. Besides I don't know how it would do in the sweetwater shes only seen salt. I laugh when guys here talk about fuel use between a 10 hp and a 20 hp motor. My boat has a 300 hp Chevy I built and installed. It cruises at 28 knots or roughly 30 mph for you land lubbers and burns 15 gallons an hour for right around 2 mpg. If its rough it goes down from there. On a typical day if we run for tuna we can burn 60 to 80 gallons and my boat is pretty fuel efficient. Plus I don't have the range to make the canyons off the coast 80 miles. Those guys can burn 200 gallons a trip or more :thumbs2: Share this post Link to post Share on other sites
Hydro 131 #10 Posted October 16, 2011 Nice job on the hitch. I like your remake better but I love the way you did the weights. Are they cast into a mould? If so I'm thinking you could do front wheel weights that way as well. Share this post Link to post Share on other sites
118lfd 8 #11 Posted October 17, 2011 Nice job on the hitch. I like your remake better but I love the way you did the weights. Are they cast into a mould? If so I'm thinking you could do front wheel weights that way as well. Yea the mold is a 12" cast iron skillet. I melted it down in the skillet and just made sure the skillet is level. I just kept adding lead till the skillet was full. Then let it cool. It slips right out. I then just skim coated the lead with bondo so I could smooth them out. You dont want to sand Lead!!!!!. Used a piece of aluminum to skim the slag off while the lead is molten. The best part is the taper of the skillet centers the weights and holds them in place. Lining up the bolts is tough but not too bad. Here is how I made them. http://www.wheelhorseforum.com/index.php?...topic=25143&hl= Share this post Link to post Share on other sites
can whlvr 994 #12 Posted October 17, 2011 nice job on the weights and hitch,real nice fishing boat too,i have a smaller boat than that and it can swallow the fuel too,its got a 240 hp mercruiser thats old and not fuel efficiant,i could easily burn 200 300 a day and not be running all either Share this post Link to post Share on other sites
mr.pipes 4 #13 Posted October 17, 2011 Nice job on the hitch. Are you still able to use your bagger with the hitch? I can't really tell from the angle of the pics. Share this post Link to post Share on other sites
118lfd 8 #14 Posted October 17, 2011 Nice job on the hitch. Are you still able to use your bagger with the hitch? I can't really tell from the angle of the pics. Share this post Link to post Share on other sites
118lfd 8 #15 Posted October 17, 2011 :thumbs2: I also build fishing rods. I built all 36 of mine. Its another addiction Share this post Link to post Share on other sites
HorseFixer 2,013 #16 Posted October 17, 2011 We fish all over but I think Michigan is a little too far a run. Besides I don't know how it would do in the sweetwater shes only seen salt. I laugh when guys here talk about fuel use between a 10 hp and a 20 hp motor. My boat has a 300 hp Chevy I built and installed. It cruises at 28 knots or roughly 30 mph for you land lubbers and burns 15 gallons an hour for right around 2 mpg. Stay away from the Flemish Cap! Yeah I laugh too! Ill take it to the Air my Cherokee 180 Burned about 11 GPH at cruise but I hauled azz with a good tail wind at about 200mph. to fast to go fly fishin! :banghead: Share this post Link to post Share on other sites
