Lanco1989 0 #1 Posted October 10, 2011 I have a 1971 800 special with an 8hp briggs. I need a carb rebuild kit but the local service shop wont help me unless I have the engine model numbers. At some point the plates were taken off. I could use any help possible thank you. :banghead: Share this post Link to post Share on other sites
rmaynard 16,538 #2 Posted October 10, 2011 If the engine is original, it should be a 190434-0825-01. Share this post Link to post Share on other sites
C-Series14 15 #3 Posted October 10, 2011 Just so you know, you could go into the model number list on here and get alot of info... If this is the original engine, the model number and spec number is 190434-0825-01. The tractors VIN is 1-0150 Share this post Link to post Share on other sites
C-Series14 15 #4 Posted October 10, 2011 Just so you know, you could go into the model number list on here and get alot of info... If this is the original engine, the model number and spec number is 190434-0825-01. The tractors VIN is 1-0150 Share this post Link to post Share on other sites
